Oily Differential (pic) - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-06-2012, 09:32 PM Thread Starter
Date registered: Jun 2011
I just topped off the differential with a quart of oil and really need to fix the problem.
I am guessing I have seals gone and am wondering how difficult it is to repair.
How much do I need to remove to be able to fix it and how long would it take the average guy with average abilities?
Thanks for your help
Gertrude-Caroline is offline
post #2 of 3 (permalink) Old 02-07-2012, 10:04 AM
wbain's Avatar
Date registered: Dec 2003
The front seal could be leaking or the cover could be leaking. Clean the differential housing and see where the leak is.
Don't lack the car up by the diff housing because the rear mount can be damaged. The rear mount can be checked by looking at how much the rubber has moved downward in the outer housing. It's fairly easy to repair. There are also other rubber mounts that may need to be replaced, which are all similar to the later models, 107, 116, 123, 124, 126 etc.
wbain is offline
post #3 of 3 (permalink) Old 02-07-2012, 12:44 PM
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 11 Post(s)
How often do you have to top it off ? (How many miles between a quart of oil)
GGR is offline
    HELP!! Differential bushing won't line up with bolt holes after lowering differential ehrichweiss W116 S, SE, SEL, SD Class 8 04-04-2011 05:20 PM
    Oily air filter!? 240D82 W123 E,CE,D,CD,TD,TE Class 20 10-08-2009 03:24 AM
    Oily Residue cameraman123 Detailing and Car Care 0 04-30-2009 09:58 AM
    Can somebody confirm this ebay differential posting? Faster 404 differential options Monstermog1964 Unimog 12 02-19-2008 07:51 PM
    Two oily questions john gregory R/C107 SL/SLC Class 0 10-10-2003 03:21 AM
