1974 230 115 --a few repair questions - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-02-2012, 07:26 AM Thread Starter
tedg's Avatar
Date registered: Jan 2012
Vehicle: MERCEDES BENZ 230 W115 1974
Hi all,
I just bought my MB 230 off of ebay. I have burned out dash board lights,and also the clock is not working. Has anyone had any experience replacing the bulbs(its a very tight job) or repairing the clock.
The hood emblem has also been broken off. Is there a place either online or a parts supplier in the Toronto area that could help.
Many thanks in advance....Ted.
tedg is offline
post #2 of 4 (permalink) Old 02-02-2012, 10:18 AM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 33 Post(s)
Start by twisting all of your fuses in their sockets to ensure they are correctly seated. If you have the aluminum fuses you may consider getting new copper ones.
Check your dash light dimmer for operation. Sometimes they get a bad spot or fail altogether. You can replace or just jumper the device. Of course, you'll have to pull the cluster.
I'm not familiar with 115 clocks, but on the older Kienzles, there are usually two things that could go wrong. There is a soldered trace acting like a fuse that may have melted. Or (and more likely, IMO) the contacts in the clockworks that close to activate the solenoid that winds the spring have corroded. These can be renewed by very lightly passing a fine abrasive paper between the contacts.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #3 of 4 (permalink) Old 02-02-2012, 01:35 PM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 102 Post(s)
The instrument cluster pulls out forward - it's friction fit with a rubber band around it that wedges it into the dash opening. Push from behind or pull from the front and it will eventually come out, then the lamps are easy to replace.
The clocks seldom work. There is a fusable link in the clock that gets fried. You can fix that but you won't know why it fried to begin with. The clocks are not very accurate anyway - my advice is to replace it with the slightly later quartz clock. Also not that easy to find but more reliable.
Scoot is offline
post #4 of 4 (permalink) Old 02-04-2012, 07:12 PM Thread Starter
tedg's Avatar
Thank you both for your knowledge...I have so much to learn...lol
tedg is offline
    B2 piston repair questions retho78 W126 S,SE,SEC,SEL,SD,SDL Class 20 02-11-2011 02:11 PM
    1974 206D Glow Plug Questions studebakerman2001 Vintage Mercedes-Benz 0 04-06-2010 10:45 AM
    Just inherited a 1974 450sl and I got some questions VWFahrenheit Vintage Mercedes-Benz 24 09-04-2009 04:43 AM
    1992 400E rust repair questions, and general restoration questions Zack1978 W124 E,CE,D,TD Class 6 10-04-2008 07:02 PM
    DAS Repair Questions ? Katmandu General Mercedes-Benz 3 07-19-2008 03:20 AM
