76 w115 300d alternator replacement w/o removing radiator?? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-29-2012, 10:43 PM Thread Starter
MissDaisy's Avatar
Date registered: Dec 2011
Vehicle: 1976 MB 300d
Post 76 w115 300d alternator replacement w/o removing radiator??
I have seen a link on this site to instructions for removing/replacing the alternator on a 76 w115 300d without removing the radiator, but the link is dead. Is there anyone who can provide information on how to do this?
I really don't want to have to get into the whole cooling system debacle if I can avoid it. Any help is definitely appreciated!
Thanks in advance!
MissDaisy is offline
post #2 of 3 (permalink) Old 01-29-2012, 11:58 PM
wbain's Avatar
Date registered: Dec 2003
Loosen the locking bolt, unscrew the lock nut on the threaded adjusting rod and relieve the tension on the belt. remove the locking bolt. Undo the lower attaching bolt(s) and drop the alternator.
Don't forget the electrical connections on the back of the alternator.
wbain is offline
post #3 of 3 (permalink) Old 02-03-2012, 03:46 PM
frankflynn's Avatar
Date registered: Feb 2011
Vehicle: 1973 220D
Quoted: 2 Post(s)
Are you sure you need to remove / replace it? You can change the brushes on this one in place. It's a single piece on the back that is the Voltage Regulator and brushes and they're cheap - definitely worth a try to replace that first.
frankflynn is offline
    Replacement Cargo Liner for '76 300D w115? Century67 Vintage Mercedes-Benz 1 04-28-2011 05:35 PM
    remove radiator to change alternator in 300D? jonesem8 W124 E,CE,D,TD Class 6 09-28-2010 03:19 PM
    Oil pump replacement W115 300D 50 cool 50 Vintage Mercedes-Benz 1 08-06-2010 12:49 PM
    Removing Alternator Tensioner on 300D Chip-In-Austin General Mercedes-Benz 1 11-16-2009 01:14 PM
    Removing Rear Seats in a w115 '76 300D smemolo Vintage Mercedes-Benz 2 12-20-2006 10:30 AM
