Engine Swap - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-29-2012, 09:20 AM Thread Starter
Date registered: Jul 2011
Engine Swap
Hello,
I need a little information. I have a 1970 250 sedan with the original
engine. This engine is worn. I have access to an engine from a 1967
250s with 60000 miles for a great price. Will this swap work easily and would
this be a good idea? Is this engine out of the 67 known to be a good one?
Thanks in advance for the help.
MaryT is offline
post #2 of 3 (permalink) Old 01-29-2012, 10:00 AM
wbain's Avatar
Date registered: Dec 2003
The 250S engine will fit because they are basically the same. The engine will need to be disassembled and checked because of its age.
You can also disassemble the original engine and check the pistons for wear. If they are OK, the rings will need to be replaced, you can get the block sleeved and bored to the correct dimension because new pistons are expensive. Something to think about.
The carbs will need to be overhauled. Check the valve guided and do a valve job. Watch for head warp.
wbain is offline
post #3 of 3 (permalink) Old 01-29-2012, 07:19 PM Thread Starter
Thanks for the quick response. I really appreciate it.
MaryT is offline
    W203- Is a 2003 engine compatible with a 2006? can I do a full/clean engine swap? TWINBENZS1989 W203 C-Class 1 10-05-2011 04:58 PM
    can I swap a 1998 ML320 engine 112 original for a 163 engine 3.2 Liter samminik W163 M-Class 0 10-17-2010 08:23 PM
    86 Mercedes Benz 420SEL Engine SWAP??? For a 380SE Engine pimpdaddy3413 W126 S,SE,SEC,SEL,SD,SDL Class 15 09-01-2009 12:11 PM
    300e 1991 w/ engine swap 1989 - Engine Problem KillerTomatos W124 E,CE,D,TD Class 8 02-26-2009 03:54 PM
    engine swap info?? euro engine in US car running rich HeirKranz W126 S,SE,SEC,SEL,SD,SDL Class 14 04-28-2005 06:18 AM
