78 300D low compression - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-23-2012, 03:04 PM Thread Starter
Date registered: Jan 2012
I bought a 78 300D with 274K miles about 3 months ago. Now it will not start. After replacing the glow plugs, injectors, adjusting the valves and checking the fuel system, I have narrowed it down to low compression. My compression is below 200 in all cylinders. A shop checked compression a few months ago and said is was very good.
What could cause such a loss in compression in all cylinders? Is it more likely something with the head, or piston rings?
Last time I drove it, it ran fine. The next morning it would not start.
Thanks
tstoller is offline
post #2 of 5 (permalink) Old 01-24-2012, 05:03 AM
Date registered: Aug 2009
Quoted: 53 Post(s)
Did you get the compression readings from the shop? "Very good" readings could be simply the fact they are not familiar with diesels. A shop dealing with gasoline powered engines would be impressed with 250 p.s.i. whereas in the diesel world it is actually bare minimum.
Mike D is offline
post #3 of 5 (permalink) Old 01-24-2012, 03:51 PM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
Did you check the compression with the engine warm (around 80º C)?
Govert70227 is offline
post #4 of 5 (permalink) Old 01-24-2012, 06:58 PM Thread Starter
Thanks,
The shop said it was close to 400 on all cylinders. They specialize in old mercedes.
The engine was not warm when I did the compression check, but it should be getting more than 160-200 when cold.
I am pulling the head this week. I have a bad feeling it's the piston rings, because the engine had a lot of blow by.
tstoller is offline
post #5 of 5 (permalink) Old 01-24-2012, 11:56 PM
Quoted: 4 Post(s)
The FSM says to check the compression with a warm engine. There can be 10 bar (145 psi) difference between cold and warm. Compression does not suddenly drop from 400 to 200.
    300D Compression & Leakdown Tests - Need Help Interpreting Results jmcqueen W123 E,CE,D,CD,TD,TE Class 8 06-03-2015 10:19 PM
    300D Turbo won't start after biodiesel fill. Compression? Dieselboy300D W123 E,CE,D,CD,TD,TE Class 19 11-20-2011 11:20 PM
    Engine Compression questions - running high compression nav_bhandher W126 S,SE,SEC,SEL,SD,SDL Class 0 06-21-2007 09:34 AM
    Whats the Exact Compression On a New 300D Turbo or NON? DieselKraut W123 E,CE,D,CD,TD,TE Class 4 01-15-2006 09:23 AM
    82 300d Compression Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 1 04-09-2002 11:53 AM
