W114 Trans Vacuum Modulator - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 01-22-2012, 03:56 PM Thread Starter
QuickSilver2's Avatar
Date registered: Oct 2007
Vehicle: 1992 190e 2.6
Couple of questions on this part.
(1) Should there be any trace of oil on the IN the banjo bolt going up to the intake?
(2) Where can I get a fair price on a replacement?
QuickSilver2 is offline
post #2 of 8 (permalink) Old 01-22-2012, 06:05 PM
wbain's Avatar
Date registered: Dec 2003
No oil should be sucked up into the manifold. There is a break inside. The modulator diaphragm can me purchased at the dealer or through the Classic Center.
wbain is offline
post #3 of 8 (permalink) Old 01-22-2012, 06:40 PM Thread Starter
Thank you Sir.
So I am assuming that once I unscrew the unit then ATF will spill out from the transmision.
post #4 of 8 (permalink) Old 01-22-2012, 07:42 PM
wbain's Avatar
There will be some in there. Get the service manual for your car. MB has the CD's for these and others. I have the Ponton and Fintail CD's and there is a section on the auto trans that includes the overhaul procedures. The modulator can be unbolted and the diaphragm replaced without removing the trana from the car. Just don't change any adjustments.
wbain is offline
post #5 of 8 (permalink) Old 01-23-2012, 05:57 PM Thread Starter
Thanks for the lead, I am picking up a new modulator as well as a CD from the Classic Center tomorrow.
post #6 of 8 (permalink) Old 01-27-2012, 03:33 PM Thread Starter
I'm 0 for 2.
It wasn't the modulator, no biggie but the manual won't load up on both my iMac and Windows NetBook.
Is it a crime to set fire to ones own car?
Quick "not having much luck" McSilver
PS: My Girlfriends Daughter took this pics when she went to pick up the aforementioned parts at the center.
https://picasaweb.google.com/OsiTech...eat=directlink
post #7 of 8 (permalink) Old 01-27-2012, 06:02 PM
wbain's Avatar
Great pics.
As for the CD, all the PDF's are in there so you might create your own index.
If it's not the modulator, then what?
wbain is offline
post #8 of 8 (permalink) Old 01-27-2012, 06:57 PM
justboo2u's Avatar
Date registered: Dec 2011
Vehicle: 86 300e Anke
If your CDs are anything like mine...
OPEN (not start) the PROGRAM folder,
and RUN the WEB FILE called MATRIX. (there are 2 of different 'types')
Of course, if you dont see matrix-ANYTHING, you dont have what I do,
and this wont be any help at all.
justboo2u is offline
    Modulator Valve W114 Automatic Trans lancerevo5 Vintage Mercedes-Benz 10 01-14-2012 12:08 PM
    Disconnected my trans vacuum modulator the other night 855r W126 S,SE,SEC,SEL,SD,SDL Class 1 01-17-2011 08:16 PM
    Vacuum Modulator ventura300se W140 S-Class 7 08-06-2009 04:19 AM
    Vacuum modulator snakehips916 W201 190-Class 3 04-04-2008 04:13 PM
    VAcuum modulator.... Samoila Stefan W201 190-Class 1 10-28-2006 08:13 AM
