1975 450 SL - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-16-2012, 03:09 PM Thread Starter
Date registered: Mar 2011
1975 450 SL
Good afternoon.
My uncle recently purchased a 1975 450 SL. He told me about some issues he is having with the car, hoping that I could find some answers online (he is not computer savvy.)
He is a mechanic by hobby, though he rarely works on anything manufactured outside the states (his three babies are a 1971 Cuda convertible, 1969 Cuda fastback and a 1971 Dart swinger.)
A few weeks ago, while driving the 450 SL, he started to hear a "clatter" and then experienced a loss in power, he described it as "running on 4 cylinders." After inspection he noticed the plastic guide for the timing chain had broken. He replaced it, inspected the valve train, noting everything appeared solid, but also noticed clearance between the valves and lifters. He started the motor and again noticed the "clatter", and shut it off. That is where the car now stands.
He mentioned the status of the valve train because he doesn't think valve/cylinder damage occurred.
I know him to be a knowledgeable mechanic, but Mercedes' are a new beast, and he is looking for advice.
I am happy to read, so please share links if they are applicable. Thanks for the help.
- James
red-560sl is offline
post #2 of 3 (permalink) Old 01-16-2012, 06:39 PM
wbain's Avatar
Date registered: Dec 2003
Quoted: 4 Post(s)
This is a know problem with these engines. Failure to change the oil on a regular basis coupled with a work chain guide on the drivers side causes the end to break off and get between the chain and the sprocket. additionally, chain wear contributes to this as well. Timing skips a tooth or two causing valve damage. Remove the cyl head(s) and replace the bent valves.
Conversely, get another engine and replace the bad one. Replace the chain and the guides in the replacement first.
wbain is offline
post #3 of 3 (permalink) Old 01-16-2012, 08:18 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
A really quick check would be to pull the fuse to the ECU(so the car won't start) and crank it. if it cranks unevenly it indicates some cylinders have more compression than others= bent valves. Slightly more time comsuming but more conclusive is pulling the cam covers and checking the cam timing and checking compression.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
1975 500 SL need help Paul Slovak Vintage Mercedes-Benz 2 05-22-2011 12:36 PM
1975 280 ECU? Mark633CSi Vintage Mercedes-Benz 1 08-11-2009 06:54 PM
need help with 1975 450 se bscott Vintage Mercedes-Benz 2 01-07-2007 07:56 PM
1975 300 d mrchuck85 Vintage Mercedes-Benz 1 08-08-2005 04:13 PM
1975 450 SL F O R S A L E ! ! ! ! Guest (MBNZ) R/C107 SL/SLC Class 0 07-19-2002 05:40 PM
