W109 height setting? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-12-2012, 07:39 PM Thread Starter
Date registered: Aug 2006
Vehicle: 1972 300SEL 4.5, 1971 Citroen DS21, 1995 Jaguar XJS
Hi!
Finally installed good air valves on my 72 300sel 4.5 W109. I can't find the specs for the height adjustment, can anyone provide the correct spec, or perhaps measure their air-suspended 109 car front and rear height while in drive position?
Thanks a million, guys!
Joe
LA
tcb323 is offline
post #2 of 4 (permalink) Old 01-13-2012, 03:50 AM
wbain's Avatar
Date registered: Dec 2003
As long as the axles are horizontal, it will be fine. Do not make the adjustment at the rear when the car is on the ground. Take it to an alignment shop and then adjust it.
How are your rear sway bar bushings? Have you greased the brake bushings? Have you drained the air tank? Are you using denatured alcohol in the air suspension inlet cup (the proper name escapes me at the moment)?
The International M-100 Group can answer all your air suspension needs.
wbain is offline
post #3 of 4 (permalink) Old 01-14-2012, 09:45 PM Thread Starter
Thanks for the reply. Suspension bushings are good. Did a full LOF. blew out air tank, alcohol in atomizer reservoir. So far it has stayed up for 72 hours without dropping at all.
I don't understand your note to not adjust height while on ground and to use an alignment rack.. should I adjust height on stands with suspension unloaded?
I thought the procedure was to adjust the height airvalve via the airvalve rod ball ends and swaybar bracket so the car sits at a certain height, it's that ride height spec I need. Anyhow, I now have the car sitting at about 26.5" level ground to beltline trim at rear wheel center, 26.25" at front. seems to be a good stance and looks 'right'. Going for a ride tomorrow to see how it handles.
Thanks !
tcb323 is offline
post #4 of 4 (permalink) Old 02-08-2012, 04:00 PM
Date registered: Feb 2012
Thanks !
hey bro, could you pm me. im in LA and i need some advice so maybe i could call you. thanks
iosonointerista is offline
    w109 rh wing wanted chewy For Sale/Wanted/Trade/Giveaway 0 09-13-2011 04:02 AM
    w109 suspension setting for storage oldbenzfan Vintage Mercedes-Benz 2 10-31-2010 07:13 AM
    W109 J C Siu Vintage Mercedes-Benz 2 01-19-2008 02:18 PM
    w109 300sel 6.3 w108 300d Vintage Mercedes-Benz 9 04-19-2006 04:47 AM
    300 SEL 6.8 AMG W109 (428 hp, 285 km/h) Onkel-Benz Vintage Mercedes-Benz 0 09-29-2004 02:22 PM
