140mph vs 160mph - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-12-2012, 10:16 AM Thread Starter
NorCalSL's Avatar
Date registered: Jun 2007
Vehicle: '70 280S-'73 450SLC-'81 380SL-'84 500SEC Euro-'92 300SL24-'95 E320
Quoted: 22 Post(s)
Exclamation 140mph vs 160mph
Does anyone know if a 140mph speedometer in a 1970 W108 280S can be replaced with a W108 160mph without changing any calibration settings? In other words, will it read correctly?
dws
1973 Mercedes 450SLC (PineGreen/MahoganyLeather)
1981 Mercedes 380SL FORSALE (LtIvory/PalominoMBTex)
1984 Mercedes 500SEC Euro (040Black/BlackLeather)
1992 Mercedes 300SL-24 Signal Red/Black Leather
NorCalSL is offline
post #2 of 4 (permalink) Old 01-12-2012, 03:06 PM
GGR
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 19 Post(s)
speedos are calibrated with the rear axle ratio. So you need to know what was the rear end ratio of the donor car compared to yours.
GGR is offline
post #3 of 4 (permalink) Old 01-13-2012, 10:42 AM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
If it is a 160mph then it came out of a 4.5 with a 3.27 rear axle. There are companys that make geared correction boxes-do a search. here is a example:
Mechanical Speedo Correction Box - Install with Pics - YotaTech Forums
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #4 of 4 (permalink) Old 01-13-2012, 02:31 PM
GGR
Vehicle: W111 Coupe
Quoted: 19 Post(s)
It could also be out of a 3.5 with 3.46 or 3.69 (or even 3.92 as an option) or out of a 6.3 with a 2.82 or 2.85 rear end.
You can cheat by putting back the 140 mph face on the 160mph mechanism. If your rear end is 3.92 and if the donor is a 3.27, your final indication will show 95 mph instead of 100 mph. If you have 205/70-14 instead of the original 185/14, your indication will be nearly correct, given that originally indicated speed is usually a few mph over the true speed.
GGR is offline
    C32 AMG 50-140MPH Eurocharged 185MM 2002c230 W203 C-Class 0 04-11-2011 06:56 PM
    140mph +++? duketango R171 SLK-Class 22 03-10-2006 02:52 PM
    140mph with the roof down Anthony100 R171 SLK-Class 17 04-15-2005 03:24 PM
    Smooth Ride going 140mph ML 500 W163 M-Class 8 12-03-2003 01:06 PM
    OT: SVT dealer takes 140mph test drive in '03 Cobra Regice R170 SLK-Class 1 09-26-2002 11:30 AM
