107 rear spring spacer replacement - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-09-2012, 06:49 AM Thread Starter
Date registered: Sep 2011
Vehicle: 1978 450 sl
Once the shock is unhooked, does the spring have to be compressed, or can I pull the lower arm down enough to r&r the spring spacer?
casinogoer is offline
post #2 of 2 (permalink) Old 01-09-2012, 09:29 AM
wbain's Avatar
Date registered: Dec 2003
There is a W107 forum farther down, but yes, the spring must be removed. Look at the front of the trailing arm and you will see a hook like stop. Removal requires a special spring compressor.
wbain is offline
    spacer for coil spring nipon G-Class 1 12-16-2007 04:19 PM
    W203 Rear Spring replacement lightspeed99 W203 C-Class 1 09-14-2007 05:43 AM
    Instructions on rear spring replacement louie270 W163 M-Class 1 02-02-2006 12:04 PM
    Rear Spring spacer sizes... H&R Peter R170 SLK-Class 0 03-01-2004 03:18 PM
    POLL What is the BEST Eibach Spring Spacer points combination Front/Rear Peter R170 SLK-Class 0 05-08-2002 08:27 AM
