W108 Window Wiring Diagram - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-07-2012, 02:39 PM Thread Starter
madmax442's Avatar
Date registered: Mar 2010
Vehicle: 2005 E500 & 1970 280SE
Quoted: 2 Post(s)
1970 280SE -
The left rear window had no power getting to it. All the other windows work. I have a Haynes Manual 63020. It has 5 pages of wiring diagrams, but the wiring for power windows is missing. What am I missing here? Where can I find a wiring diagram for the windows?
madmax442 is offline
post #2 of 5 (permalink) Old 01-07-2012, 04:48 PM
QuickSilver2's Avatar
Date registered: Oct 2007
Vehicle: 1992 190e 2.6
I stand to be corrected but "I" think power windows and even air conditions, on certain cars, were dealer option. Meaning they did not come from the factory but were impregnated local at the dealership thus not included in the wiring diagram.
Good luck.
QuickSilver2 is offline
post #3 of 5 (permalink) Old 01-07-2012, 08:47 PM
Date registered: Aug 2010
Vehicle: 73 300SEL 4.5
W108/109 came with factory power windows in america. I believe this is the correct wiring diagram for your car.
good luck
thusa is offline
post #4 of 5 (permalink) Old 01-08-2012, 09:29 AM Thread Starter
madmax442's Avatar
Quoted: 2 Post(s)
Thank you! thusa! awesome
post #5 of 5 (permalink) Old 01-08-2012, 01:21 PM Thread Starter
madmax442's Avatar
Quoted: 2 Post(s)
I was able to find the problem from the wiring diagram, thanks again. Someone had moved the terminal from the front switch to a blank opening in the switch housing (weird). My guess is the the window was not rolling up right and they disabled it by moving the hot terminal. It turns out the regulator was dry and crusted over with old greese. Removed the regulator, cleaned and relubed everything with white lithium greese. Works great now. I worked on a lot of cars in my day. The Merc is probably the best engineered one yet.
Michael Maxwell (madmax442)
    window switch wiring diagram jfletcher72 W126 S,SE,SEC,SEL,SD,SDL Class 12 12-05-2011 03:39 PM
    wiring diagram W108 4.5l brianhymer Vintage Mercedes-Benz 5 11-24-2010 02:50 AM
    Wiring Diagram for the Softtop and window Chris7747 R129 SL-Class 0 01-03-2008 08:27 PM
    90' 420sel window switch wiring diagram ??? 300sd W126 S,SE,SEC,SEL,SD,SDL Class 2 08-06-2007 10:52 AM
    w108 power window wiring? mclaypool Vintage Mercedes-Benz 19 01-29-2007 01:07 AM
