w113 "Tall Fuel Pump" to "Short Fuel Pump" conversion - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-07-2012, 02:45 AM Thread Starter
Date registered: Aug 2009
Vehicle: W107 W113
Quoted: 29 Post(s)
Has anyone tried this conversion?
I think it would be fairly easy to do, it seems that normal "CIS" fuel pumps would work just fine.
R107
S320L1999 is offline
post #2 of 3 (permalink) Old 01-07-2012, 04:55 AM
wbain's Avatar
Date registered: Dec 2003
That won't really work. The original pump is low pressure and high volume. That CIS pump is high pressure. There are two styles of the original pump, the early tall pump and the later short pump. They are both high volume low pressure delivering about a gallon a minute.
Check The International M-100 Group for info on how to overhaul the original pump in the forum section under fuel system. Also check Welcome - Mercedes Benz 230SL, 250SL, 280SL Pagoda Group for more information. These cars use the same type of fuel system and electrics. Holley has a similar pump but the dimensions are different. I bought one from a speed shop made by 'Big End' #10150.
wbain is offline
post #3 of 3 (permalink) Old 01-07-2012, 06:30 AM Thread Starter
Vehicle: W107 W113
Quoted: 29 Post(s)
Hi, great thank you.
Is there a website for those Holly pumps?
R107
    1993 400 SEL runs fantastic with "ONE" fuel pump! bradsscooters W140 S-Class 2 10-25-2010 10:07 PM
    How can one know if a "cheap" fuel pump works for a 280se? Mr.Benz1 Vintage Mercedes-Benz 7 04-15-2010 07:59 PM
    Fuel pump "Filter Screen" Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 9 09-07-2006 12:24 AM
    Clean "Fuel Pump bayonet connections" Chupper W124 E,CE,D,TD Class 1 12-03-2002 07:46 AM
