1976 MBZ 280 temp gauge issue.. - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 01-05-2012, 05:06 PM Thread Starter
BlueSkiesWhiteClouds's Avatar
Date registered: May 2011
Can anyone relate to this most recent issue with my temp gauge???
I noticed while sitting in the drive thru line that my gauge was reading in the 200 area when it normally sits at about 140 or lower...I did notice that the car has been idling ok but does make a very low "puup puup" sound...kinda like a bubbling sound from the exhaust i suppose.. any suggestions? Thanks in advance.
BlueSkiesWhiteClouds is offline
post #2 of 4 (permalink) Old 01-06-2012, 03:11 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 103 Post(s)
200 degrees isn't bad - it's still within normal range. You have a circuit that activates the aux fan at 212 degrees. I'm not familiar with what "too hot" is, but I *think* it's 250.
Grubeguy is offline
post #3 of 4 (permalink) Old 01-07-2012, 09:26 PM Thread Starter
thx GRUBEGUY
post #4 of 4 (permalink) Old 01-08-2012, 01:30 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
140F is too low. The thermostat opens at around 190F. The temperature needle should be between the 175F and 250F mark.
Govert70227 is offline
    brake lights, fuel gauge, temp gauge quit working badwin W201 190-Class 12 07-24-2015 06:55 PM
    Help! Right brake light, cruise control, fuel gauge, temp gauge, oil gauge out rsteckly W201 190-Class 1 09-27-2011 04:25 PM
    Temperature variance -- actual temp vs. gauge temp reading soundquest W124 E,CE,D,TD Class 7 06-19-2011 08:03 AM
    Temp Gauge Issue?? Jagster W210 E-Class 21 10-30-2009 07:04 AM
    Problems fitting 500 fuel gauge-oil pres'-water temp gauge cluster to 560 clocks mutley666 W126 S,SE,SEC,SEL,SD,SDL Class 2 10-10-2005 09:03 AM
