Has Anyone Installed a Vaico Fuel Pump? - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 01-05-2012, 04:07 PM Thread Starter
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 36 Post(s)
I wanted to replace my fuel pump on my m180.945 engine but couldn't find a Pierberg which is OEM. So I bought a Vaico brand pump. It looks cheap (and it was cheap) but I figured it would be better than the old one I had on the car.
I installed it today and it leaks a good deal of oil out the weep hole on the bottom of the pump. I verified that it wasn't leaking around the gaskets with a mirror.
So my questions are these: can I plug the weep hole with something to stop the leaking (the car runs fine with this pump), or does the weep hole need to breathe for proper operation of the pump? Should I just take my chances and put the original pump back on, figuring the Vaico is just another crappy aftermarket part?
The main reason I'm replacing the original pump is that gas drains down out of the line when the car sits. It takes 5 or 6 tries to get it started. I figured the check valve in the pump is weak. I'm fully aware of the evaporation problems my Solex carbs have, but this is ridiculous (and hard on the starter).
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
    Fuel Pump, Fuel Pump Relay or something else? W126fahrer W126 S,SE,SEC,SEL,SD,SDL Class 24 10-24-2013 09:03 AM
    Primer pump won't pump. No fuel coming to pre filter. Dieselache W123 E,CE,D,CD,TD,TE Class 3 06-16-2011 05:55 AM
    Installed new fuel pump - pictures Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 21 08-17-2006 04:15 PM
    380sel where is the fuel pump fuse? have no power to pump meggala W126 S,SE,SEC,SEL,SD,SDL Class 3 08-02-2005 04:44 AM
