Installing Hot Spark Ignitor - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 01-13-2012, 03:12 AM
Date registered: Aug 2009
Quoted: 49 Post(s)
Yes, you originally had two wires leading to the positive terminal on the coil. One wire came from the starter solenoid and was a full +12V. It was energized only when the starter cranked supplying direct voltage for an added boost. The second wire was a reduced voltage coming from the ballast resistor. This circuit is powered at the "run" position of the ignition switch.
Mike D is online now
post #12 of 13 (permalink) Old 01-15-2012, 02:10 AM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 32 Post(s)
Hmm, the Hot Spark units you speak of - I have used Pertronix and was about to order a kit tomorrow for my 280S motor. But now I hear of these - what is the difference, how do they compare? These seem a little cheaper!
And Mike, do you have a thread on your conversion to aftermarket FI at all? Was it worth the trouble?
Thanks, Drew in Oz
drew56cus is offline
post #13 of 13 (permalink) Old 01-15-2012, 05:27 AM
Quoted: 49 Post(s)
The "Hot Spark" and the Pertronix are essentially identical. The Pertronix design copyright expired and the HS boys are making copies with a licensing agreement with Pertronix.
I think the HS is about $20 USD cheaper. I went with HS over Pertronx simply because HS are "little guys" trying to make a go of it and they are closer to me.
I have write-ups on my M110, M117 and M115 conversions on other boards.
The M115 write-up is at "Peachparts", the M110 is on "Stroke8" and I forget where the M117's is. It might be at "PP" or over on the Megasquirt board under "Success stories"
    Petronix Ignitor for 404 karoja Unimog 9 12-21-2006 08:21 PM
    defective BIX ignitor alanchan W203 C-Class 4 11-24-2006 03:53 PM
    Ignitor Box ???? kennyglas R/C107 SL/SLC Class 8 10-17-2005 07:23 AM
    What does the ignitor do? lnguyenh General Mercedes-Benz 2 01-02-2005 08:27 AM
    Installing Spark Plugs 1989 420 SEL sali General Mercedes-Benz 0 05-30-2004 12:27 PM
