Question On Bolt Pattern/Offset For W114 - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 01-06-2012, 03:08 PM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 118 Post(s)
Originally Posted by QuickSilver2 View Post
Are the wheels you are refering to?
No. Those are rather crappy 14" Bundt wheels from a W126, however the one inside the trunk of that car is pretty nice, and yes I have seen the car, it's a bargain if you want a parts car and probably a problem if you want a driver, and it completely needs paint which is more expensive to do than the cost of a good W126...
I'm having second thoughts about the offset on W126 (and W107)... I'm a bit out of my area with W126 and W107 and it is possible that early W126 had a different offset than late W126. Same with W107. I'm not sure, you would have to consult someone who knows more about those than I know. I'm pretty darn sure that any W126 that has over 14" rims has an offset that is not compatible with the offset on the 108/113/114 etc cars.
Scoot is offline
post #12 of 12 (permalink) Old 01-06-2012, 03:33 PM Thread Starter
QuickSilver2's Avatar
Date registered: Oct 2007
Vehicle: 1992 190e 2.6
Duly noted. Thanks Sir.
QuickSilver2 is offline
    Case U900 Wheel Bolt Pattern and Offset Ztoe Unimog 3 04-17-2010 12:08 AM
    What's the Bolt Pattern and Offset for the ML (163) Darkmann W163 M-Class 1 05-15-2006 12:02 PM
    G-Class Wheels -bolt pattern, offset, sizes, etc. Jade Pig Racing G-Class 4 12-22-2002 11:13 AM
    Correct wheel bolt pattern and offset MAC10 W202 C-Class 0 11-20-2002 06:38 AM
    Re: Rim bolt pattern & offset for R230 Guest (MBNZ) R230 SL-Class 5 12-11-2001 02:23 PM
