1973 115 rust repair - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-02-2012, 01:52 AM Thread Starter
Date registered: Jan 2012
Heya, new to the forums here. I am trying to salvage my 115. It has extensive rust throughout the floorboards, which is getting dangerously close in the backseat area to some bolted on mounts. I've located panels and am preparing to cut out the floor boards and weld in the replacement sheet-metal. I have no experience welding. My plan is to do the cutting/grinding/clean-up myself and pay a pro to do the welding (unless anyone thinks that it is realistic that I could rent a MIG and fly by the seat of my pants). I was hoping to get some pointers from people with experience doing this repair. At this point, not having actually torn the seats/carpet/soundproofing out, it looks like both sides will need to be removed from front to back and replaced. I don't have access to a lift and will probably be doing the repair with the car on ramps. Thanks in advance.
P.S. Also trying to locate a manual for 115 220D if anyone knows of one for sale.
donnierhodes is offline
post #2 of 5 (permalink) Old 01-02-2012, 06:00 AM
GGR
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 19 Post(s)
GGR is offline
post #3 of 5 (permalink) Old 01-02-2012, 10:54 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Are you using straight sheet metal, or do you have replacement floorboards? Ether case isn't too awfully daunting. I had (have?) no welding skills but did the same thing with my 108. I would recommend watching a couple "how to" videos and just rent a rig for a weekend. After the welds are done, grind them down and check for structural integrity.
Good luck!
Grubeguy is offline
post #4 of 5 (permalink) Old 01-02-2012, 04:46 PM
madmanmerc's Avatar
Vehicle: 1970 250c, 300e amg
Quoted: 17 Post(s)
i made my own floor panels actually. it took me 3 whole days to cut out, clean and weld in the new floors. if the job is done right (as mine was) and the welds are grinded down, you shouldnt be able to tell the panels are homemade.
madmanmerc is offline
post #5 of 5 (permalink) Old 01-02-2012, 04:48 PM
madmanmerc's Avatar
Quoted: 17 Post(s)
by the way, does anyone know if Al in the previous post used replacement panels or made them. If replacements, where did he get them. thanks
    Rust repair e430wy W210 E-Class 3 10-30-2008 08:10 PM
    Rust Repair by MB donald1111 W210 E-Class 9 01-21-2007 02:41 AM
    Rust Repair by MB donald1111 W210 E50 AMG, E55 AMG 0 01-20-2007 08:22 AM
    Rust repair Guest Vintage Mercedes-Benz 3 04-24-2005 11:32 PM
    Rust repair jrehm W123 E,CE,D,CD,TD,TE Class 1 08-23-2004 09:31 PM
