1963 190C horn - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-29-2011, 10:45 PM Thread Starter
Date registered: Feb 2011
1963 190C horn
I am trying to get the horn working. I hot wired to the horn, which did not work, so I bought a generic horn. Still not working, so I am now looking for a horn relay that supposedly exists. Anyone know where the horn relay is and what it looks like? I bought a replacement from the local NAPA store, but I don't see anything that resembles it either in the engine compartment or under the dash. I have tried tracing the wires from the horn to the fuse box as well as from the steering column out. Still no luck...
nervedoc is offline
post #2 of 4 (permalink) Old 12-29-2011, 11:48 PM
wbain's Avatar
Date registered: Dec 2003
There is no relay. Check the horn power connections.
Remove the turn signal rubber cover and you will see two wires attached by screws. They go to the contacts under the steering wheel. Check all connections.
If necessary, take the steering wheel off and check there too.
wbain is offline
post #3 of 4 (permalink) Old 01-02-2012, 01:42 PM Thread Starter
FIXED!
Loose connection under steering wheel, thank-you!
nervedoc is offline
post #4 of 4 (permalink) Old 01-02-2012, 06:32 PM
wbain's Avatar
excellent.
wbain is offline
    W110 1963 190C transmission nervedoc Vintage Mercedes-Benz 5 11-15-2011 12:40 AM
    Carburetor W110 1963 190c nervedoc Vintage Mercedes-Benz 0 11-14-2011 11:05 PM
    W110 1963 190C transmission nervedoc Vintage Mercedes-Benz 1 10-04-2011 02:28 PM
    190c w110 Vifa Vintage Mercedes-Benz 2 03-10-2010 11:31 AM
    190c parts? 1963_190c Vintage Mercedes-Benz 1 02-11-2010 06:58 PM
