240D - Oil in injection pump? - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 12-19-2011, 07:22 PM Thread Starter
Date registered: Sep 2011
Vehicle: 1974 Mercedes Benz 240D
Dear Forum:
I was noticing today that there is an oil cap on the injection pump. How much oil should it have in it? How do I measure it? And, what kind of oil should I put in it? I put a screw driver down in it and couldn't detect any oil. It's been working perfectly, but that concerned me.
faberm is offline
post #2 of 9 (permalink) Old 12-20-2011, 12:47 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
The oil in the pump should be changed/renewed every time you change the engine oil. The pump needs engine oil.
Unscrew the bolt at the red arrow in the picture below. Pour in oil at the top (blue arrow) until clean oil comes out of the bolt. The bolt is a banjo bolt, so you don't need to remove the bolt, just unscrew. It usually takes about 200 ml (that is about 6.5 fluid ounces).
If you haven't changed oil for a long time, there might be a lot of diesel first that comes out of the bolt.
It is a bit messy, so have some rags under the bolt.
Govert70227 is offline
post #3 of 9 (permalink) Old 12-20-2011, 06:35 PM Thread Starter
How do I know when it is filled enough? Ie...do you put in a stick or something to have it filled to a certain level?
faberm is offline
post #4 of 9 (permalink) Old 12-20-2011, 11:32 PM
Quoted: 4 Post(s)
The bolt is the fill level, so open the bolt, pour in oil until clean oil comes out of the bolt, close bolt and you are done.
post #5 of 9 (permalink) Old 12-22-2011, 02:27 PM
Hakan Alın's Avatar
Date registered: Nov 2010
Vehicle: 1974 240 D w115 OM 616.916
Send a message via MSN to Hakan Alın
i was never ever able to reach that bolt, i put 250 ml of engine oil from the red cap at every engine oil change...
Hakan Alın is offline
post #6 of 9 (permalink) Old 12-23-2011, 05:00 AM
Quoted: 4 Post(s)
The oil level will get to high and in the end, it will flow out of the vent pipe on the back of the pump.
post #7 of 9 (permalink) Old 12-23-2011, 09:18 AM
Hakan Alın's Avatar
does that cause any problems ?
post #8 of 9 (permalink) Old 12-23-2011, 10:03 AM
Quoted: 4 Post(s)
The high oil level can cause frothing, but that is probably not much of a problem in the pump. The diesel in the pump still causes the oil to become thin, so it doesn't provide enough lubrication.
post #9 of 9 (permalink) Old 12-24-2011, 05:15 AM
Hakan Alın's Avatar
i see, thanks for that useful information. i am going to spend more time with that bolt and unscrew it, Merry Christmas to you all...
    Injection Pump Problems 240D VEGFORLIFE W123 E,CE,D,CD,TD,TE Class 18 04-29-2014 06:59 PM
    240D Injection Pump flush??? calogero05 W123 E,CE,D,CD,TD,TE Class 8 03-21-2011 10:59 AM
    75 240D injection pump oil consumption hjackson Vintage Mercedes-Benz 10 02-06-2010 08:15 AM
    Testing injection pump on 240D frenchfry W123 E,CE,D,CD,TD,TE Class 16 11-18-2009 04:14 PM
    240D Injection Pump wdba123190 W123 E,CE,D,CD,TD,TE Class 1 08-21-2003 05:13 PM
