Throttle body stop setting for 1074 450 SEL - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-12-2011, 08:30 AM Thread Starter
Date registered: Dec 2011
Vehicle: 1974 450 SEL
I have a 1974 450 SEL with electronic fuel injection and need to know the proper adjustment for the throttle body stop. One source said one full turn clockwise once screw begins to open the butterfly valve. The engine vin is:117.893-12-014942.
Thanks, wd450SEL
wd450SEL is offline
post #2 of 3 (permalink) Old 12-12-2011, 02:25 PM
The throttle plate stop screw should not be used to set idle, there is a separate circuit for idle. So if it has been messed with, take the throttle body off, clean insides, adjust the stop by holding the body to a light and adjusting the stop until light is not seen and the valve does not "stick" The delicate flap is precisely machined to fit on an angle and not bind. and pass idle control to the idle curcuit via the throttle positioning switch on the side of the body.
this is a critical adjustment which can cause much grief (if not perfect)
Brian O
bostosh is offline
post #3 of 3 (permalink) Old 12-12-2011, 03:43 PM Thread Starter
Throttle body stop setting for 1974 450SEL
Brian, Thanks for your help! I will have to make that adjustment then re-adjust the throttle body switch. Do you have precise instructions for that process?
I continue to be in your debt.
Walter D
wd450SEL is offline
Electrronic Throttle Actuator (ETA) or Throttle Body 1993MBZ500SL R129 SL-Class 23 11-17-2014 10:59 AM
95' C280 Throttle Actuator/Throttle Body removal? FRANKTHETANK W202 C-Class 5 10-19-2013 01:12 PM
Full throttle on C36 AMG doesn't open throttle body 100%? JMPhotography W202 C36 AMG, C43 AMG 13 11-29-2010 03:28 AM
P0170 code and throttle valve stop? DanielChen W210 E-Class 20 07-17-2010 11:05 AM
Setting up throttle cable/kickdown 300SL silver50 R129 SL-Class 4 10-23-2007 06:40 AM
