280SE 4.5 injectors 2&3 not firing - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-18-2011, 11:36 AM Thread Starter
We have a problem on a M117,
No response to cylinders 2&3 while running.
At idle , I can disconnect the connectors to the injector body and no change (2,3) of idle quality
all others make a difference.
Also, during warm up, the exhaust manifold at 2,3 are cold to the touch during cold start operation. (yes I touch them)
Swapped out the 2 injectors and same result,
So I am wondering how to check the pulses at the connector to the injector body,
I have the digital volt/ohm meter, only, can I test static, or dynamic?
Compression good, good idle, no tailpipe crud blowing, valves adjusted, dirty intake manifold (old unknown seals and gaskets, an older motor,
While last run at freeway speed run mucho power at speed.
We've tried many things, plugs, points, wires, trigger points, tps, map sensor, brain box, ground connections, fuel pressure, all EFI subsystems have been cleaned, spiffed, touched and tested by substitution.
Any Ideas ?
Thanks in advance
Brian O
bostosh is offline
post #2 of 5 (permalink) Old 11-20-2011, 10:54 AM
Date registered: Jan 2004
Vehicle: 1973 280SE 4.5, 1999 E430, 2003 SL500, 2009 C300
Wow, thats frustrating after trying swaping so many pieces of the system. I dont know the answer to whether you can test static or dynamic but I would think that the problem at this point would lie in a broken wire or insulation cracked on a couple of them somewhere and they are shorting. Good luck Im looking forward to seeing what you find the problem is.
galaxyjb is offline
post #3 of 5 (permalink) Old 11-21-2011, 03:42 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 107 Post(s)
Hiya Bostosh. The cylinders fire in pairs - 1&5, 2&6, 3&7, 4&8 - and are hard wired between injectors. If 2 and 3 are unresponsive but 6 and 7 aren't, you have bad wiring or bad connection plugs.
Grubeguy is offline
post #4 of 5 (permalink) Old 11-21-2011, 07:46 AM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
If it's only 2&3, that are giving you problems, I concur on wiring problems. Check the wires that go to the ground points on the manifold.
Just to make absolutely sure: You are counting the cylinders 1 to 4 on the Left as you stand infront of the car, facing the engine) and 5 to 8 on the Right? It can be easy to get confused, if someone works on other makes of car a lot, too.
Scott
RadioTek is offline
post #5 of 5 (permalink) Old 11-21-2011, 09:03 AM Thread Starter
I am thinking wiring also. Grube and Radio I like that logic.
Is there a way to check with a meter?
I will cut back some insulation and probe between plug and solid wire.
or just cut the plug off and splice another one on?
Trial and error or trial and trial
Brian O
bostosh is offline
Injectors Not Firing gmitc W140 S-Class 43 05-11-2012 06:20 PM
85 380SL - injectors not firing 2 8 R/C107 SL/SLC Class 30 10-18-2011 09:07 AM
85 380SL - injectors not firing 2 8 C207/A207 E-Class Coupe & Cabriolet 2 03-21-2011 09:39 AM
injectors not firing pkelly450 Vintage Mercedes-Benz 6 04-29-2010 11:45 PM
I NEED firing order for 4.5L 280SE Tim Bob R/C107 SL/SLC Class 2 05-07-2006 07:24 PM
