Let's Talk W108 Brakes - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 11-17-2011, 11:44 PM Thread Starter
QuickSilver2's Avatar
Date registered: Oct 2007
Vehicle: 1992 190e 2.6
The brakes on Ingrid needs to be overhauled. I was thinking while I was at it to just upgrade it to the bigger brakes on the V8 W108s.
Interested in finding out how to do this and what to buy.
PS: I am not asking if I should or if I need to, I am asking on how to do it, especially from those that have done it before.
Thanks.
QuickSilver2 is offline
post #2 of 18 (permalink) Old 11-18-2011, 06:25 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 70 Post(s)
Upgrade to what exactly? Thrust reversers?
flyboyike is offline
post #3 of 18 (permalink) Old 11-18-2011, 07:17 AM Thread Starter
Thank God for the ignore user filter
post #4 of 18 (permalink) Old 11-18-2011, 07:40 AM
flyboyike's Avatar
Quoted: 70 Post(s)
Your loss. I was dead serious.
post #5 of 18 (permalink) Old 11-18-2011, 05:48 PM
upgrade to more perfect.
true, short of installing thrust reverser, the factory set-up is perfect.
If the hoses are replaced, pads are correct (ATE), calipers do not leak, master cylinder is good, these factory brakes (even the unvented) will cause the Porsche following you to slide under your rear bumper and fuel tank up to it's windshield and crack it.
True story. Want another?
Hammered the brakes on a 280SE 4.5 once, generated a lot of smoke, saved our asses and sheet metal, ground 3/16 of rubber off a new set of Pirellis, held straight skid, all done with stock parts and no electronics such as ABS. I had to get a new set of tires the flat spot went bump-bump-bump, horrible ride after the stop.
Another one,
same car, girlfriend driving, stomped the pedal while doing 110 MPH, she just had made a comment about the signs reading 110 KMPH, as a car pulled out ahead to pass on a two lane blacktop in Baja. That one was way tooooo close. I thought my future was in a desert in Baja
Brian O
bostosh is offline
post #6 of 18 (permalink) Old 11-18-2011, 05:54 PM
The upgrade
Get 4.5 vented rotors and wider calipers, nothing else needed.
Replace all ancillary parts stock.
Brian O
bostosh is offline
post #7 of 18 (permalink) Old 11-18-2011, 05:56 PM Thread Starter
I never said it wasn't but my question was....
"PS: I am not asking if I should or if I need to, I am asking on how to do it, especially from those that have done it before."
I'm installing either an 302 or an LT1 so I want to make sure that I improve the brakes too. You know like the factory did when they installed a V8 in it.
post #8 of 18 (permalink) Old 11-18-2011, 06:00 PM Thread Starter
Thanks for answering my very pointed question.
I'll be replacing/rebuilding the rear calipers/master.
Thanks once again.
PS: I won't even need longer wheel studs?
post #9 of 18 (permalink) Old 11-18-2011, 06:19 PM
flyboyike's Avatar
Quoted: 70 Post(s)
Especially since our friend is stubbornly refusing to tell us what he wants to upgrade to, despite his question being allegedly very "pointed". He is not willing to tell us if he wants to just get a little more braking power/effectiveness or go with some sort of a custom setup with multipiston calipers, platter-sized slotted and cross-drilled rotors, ceramic pads etc. There is upgrading and there is UPGRADING.
post #10 of 18 (permalink) Old 11-18-2011, 08:28 PM
upgrade UPGRADE
Ya know, we can stop space shuttles and 747s
How fast and how not fast is the question?
Great conversation on a friday night.
Brian O
bostosh is offline
1989 Mercedes 300CE heavy shaking when applying brakes (not front brakes/rotors) MrAlvi General Mercedes-Benz 3 09-29-2011 07:41 AM
w108 dies when I press on the brakes! hugedodge2000 Vintage Mercedes-Benz 3 09-18-2010 07:04 AM
New W108 Owner...Source for W108 Door and Window Seals? LaterApex Vintage Mercedes-Benz 5 03-24-2008 12:51 PM
All this talk about brakes lander91 W126 S,SE,SEC,SEL,SD,SDL Class 5 02-17-2006 09:55 PM
2003 C230 Sedan brakes to 2004 cross-drilled brakes? aaronmarks W203 C-Class 1 10-05-2005 04:00 PM
