'77 280E Charging system - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 11-17-2011, 04:16 PM Thread Starter
Date registered: May 2011
Vehicle: 1977 Mercedes Benz 280E
Post '77 280E Charging system
Ok so I bought this car back in may and I had to replace the alternator in it then. Since then the car has ran great with no problems about three weeks ago the battery stopped charging. I had the alternator and battery checked by my parts store and they said that both are good and should be working fine. I just cant figure this one out?
av2012 is offline
post #2 of 4 (permalink) Old 11-17-2011, 05:30 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Suppose you have perfectly good toaster and a perfectly good power outlet. The toaster is plugged in, but is not getting any juice. What would you suspect?
flyboyike is offline
post #3 of 4 (permalink) Old 11-28-2011, 08:30 AM
74benzo's Avatar
Date registered: Sep 2009
Vehicle: '74 280
Check the ground. I had to end up running another one for mine because the header had melted the coating on the wire and the wire had rusted.
1974 280
2001 Lexus IS300
74benzo is offline
post #4 of 4 (permalink) Old 11-28-2011, 07:45 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
I was cautioned by a guy that rebuilt my alternator to check the green wire to the alternator from the ignition switch. European electrical systems of that era use a (usually green) wire from the switch to the alternator that provides power to the winding of the alternator (via some circuitry inside the alt.) If that wire is not getting power, the alt will not put out any voltage/current.
if there isn't any voltage on that wire when the key is in the "run" position, then you would need to troubleshoot that. The culprit may be the ignition switch itself, which is in 3 parts. The lock/core, the steering wheel immobilizer assembly, and the switch itself. the switch is available as a seperate part, and changing it on anything other than a 107 won't endanger your sanity. (Been there. Done that. Got the T-shirt. And the scars.)
Just a suggestion,
scott
RadioTek is offline
    charging system problem? 06ml500amg W164 M-Class 0 12-18-2010 05:58 PM
    Charging System Wierdness - OVP?? lsfeder W126 S,SE,SEC,SEL,SD,SDL Class 2 12-04-2010 01:42 PM
    404 charging system minimog 401 Unimog 13 05-14-2008 06:29 PM
    1977 Mercedes 280E not charging m.c. Vintage Mercedes-Benz 3 05-27-2006 05:08 PM
    system not charging help!!! LBC500SEL W140 S-Class 1 06-04-2005 11:47 AM
