Squeaky engine (Video) - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-14-2011, 08:18 PM Thread Starter
Date registered: Jun 2011
This is my wife's 1976 240D.
The noise has been getting steadily louder and now pretty much drowns out the sound of the engine.
Squeaky 240D Mercedes Benz - YouTube
Is there typically a pulley (or pulleys) that need replacing and if so how difficult is it to do.
Also, whilst I am in replacing parts is there other work that is recommended at the same time?
Thanks in advance for your help.
Gertrude-Caroline is offline
post #2 of 5 (permalink) Old 11-21-2011, 08:01 AM
ktmripper's Avatar
Date registered: Jun 2010
Spray silicone on the pulleys one at a time, when the noise stops you have found the right one.
ktmripper is offline
post #3 of 5 (permalink) Old 12-01-2011, 04:16 PM Thread Starter
I sprayed the silicone from all angles and the noise went away BUT only for a few minutes.
So what now?
I guess I need to start replacing pulleys. How difficult will this be?
Thanks
post #4 of 5 (permalink) Old 12-01-2011, 10:51 PM
Date registered: Dec 2011
I suggest you buy a new
nickolerda is offline
post #5 of 5 (permalink) Old 12-02-2011, 03:17 PM
ktmripper's Avatar
I should have been more clear. spray on the bearing in the middle of one pulley, then start your engine. if the noise goes away that bearing is the bad one. if not, turn off your motor and continue to the next. Use just a small amount. You might also notice play or wobble in the pulley if the bearing is going out. Make sure your belts are tight and strait too. You may just need new or adjusted belts.
    Took my engine somewhat apart and made a video. C280Cambria W202 C-Class 3 06-14-2011 07:22 PM
    Engine Air Filter Video TheBenZo W220 S-Class 1 04-24-2010 09:31 PM
    300SDL Engine Removal - Video JMPhotography W126 S,SE,SEC,SEL,SD,SDL Class 7 12-06-2009 11:17 AM
    ••Squeaky...Squeaky...KABOOM...1999 E320 R.I.P.?•• Cocob W210 E-Class 6 02-23-2007 05:14 PM
    190 video w/formula 1 engine! roncor W201 190-Class 2 09-09-2006 12:42 PM
