78 450 power steering pump trouble - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-07-2011, 09:43 AM Thread Starter
Date registered: Sep 2011
Vehicle: 1978 450 sl
After resting in the garage for a few weeks, I fired up the 78, and heard the distinct "dry pump growl" coming from the power steering pump. steering is like manual, with intermittent power. The pump is spitting up fluid. Belts are ok and pulley is turning ok. Time for a pump kit? or is it something else? Please help my baby!
Steve in Kittery, Me
casinogoer is offline
post #2 of 3 (permalink) Old 11-07-2011, 12:03 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 667 Post(s)
Time for a pump. Repair kit will just reseal.
GeeS is offline
post #3 of 3 (permalink) Old 11-13-2011, 05:21 PM
ktmripper's Avatar
Date registered: Jun 2010
Did you add fluid then notice the problems? That sounds like air in the power steering system. Try to bleed your steering system. I had that exact same problem after changing a steering hose. Sometimes if you top off a very low system, you can trap air in it. It's alot easier than pulling and replacing your pump.
Oh, if you do end up changing the pump, you still need to bleed the system with the new one.
ktmripper is offline
    FS: 2007 CL550 power steering pump (ABC pump) Streetglower For Sale/Wanted/Trade/Giveaway 2 11-13-2011 06:54 PM
    HELP! w108 power-steering trouble gclass Vintage Mercedes-Benz 13 04-18-2011 05:28 PM
    Power Steering Pump vs. Hydraulic Suspension Pump jdg15 W126 S,SE,SEC,SEL,SD,SDL Class 9 10-05-2010 12:20 AM
    power steering pump, rebuild kit or used pump Tye W123 E,CE,D,CD,TD,TE Class 5 08-10-2007 09:27 PM
    92 400E Power steering pump and water pump, need advice kanio W124 E,CE,D,TD Class 5 03-19-2007 06:58 PM
