Low compression on 4,5&6 - Mercedes-Benz Forum
post #1 of 20 (permalink) Old 11-05-2011, 12:35 PM Thread Starter
alvector's Avatar
Date registered: Aug 2011
Vehicle: 1993 190e 2.6
I went out today and did a compression test on the 1972 250 and m130 motor and my findings were not very good --
1 150
2 160
3 155
4 100
5 102
6 100
you guys have any ideas on what it could be? should I start looking at the head gasket or should I assume The back three rings and pistons are bad? I get a little bit of a light knock but nothing that's concerns me. I think it is an exhaust leak more than anything.
alvector is offline
post #2 of 20 (permalink) Old 11-05-2011, 01:18 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
What kind of history does the engine have? Miles? Exhaust leaks don't usually cause a knock, more like a rumbling sound. How is the oil pressure and what does the oil look like?
flyboyike is offline
post #3 of 20 (permalink) Old 11-05-2011, 01:41 PM Thread Starter
alvector's Avatar
The car has 87,000 miles from California. It has signs of low mileage such as oil change stickers with the miles and dates on them. And some service records. The oil is clean of radiator fluid if that is what you are thinking. And visa versa.
Plugs looked good (proper detonation). I recently adjusted the valves and inspected the cam shaft. Wondering if there is some history of the back three low for a reason. I'm used to seeing one low. Can rings be done without removing the engine? Looks like the subframe might get in the way?
Thanks
alvector is offline
post #4 of 20 (permalink) Old 11-05-2011, 01:43 PM Thread Starter
alvector's Avatar
Oil pressure is max on the gauge most of the time.
alvector is offline
post #5 of 20 (permalink) Old 11-05-2011, 01:44 PM
flyboyike's Avatar
Quoted: 69 Post(s)
Let's start with what made you think of doing a compression test in the first place. What were/are the symptoms?
post #6 of 20 (permalink) Old 11-05-2011, 01:57 PM Thread Starter
alvector's Avatar
I did one, because it is a pretty new car to me. I figure, before I throw money at it with tune up parts and tranny flush and filter, I should check the core of the motor. Too many times it has been seen that people change everything only to realize that the head gasket is bad. There really are not any symptoms as far as power or acceleration, but maybe I'm just being soft on how it actually runs (ecause in the back of my head, I think it is a 40 y.o. Motor )
alvector is offline
post #7 of 20 (permalink) Old 11-05-2011, 02:00 PM
flyboyike's Avatar
Quoted: 69 Post(s)
I see. Any oil on plugs 4, 5, 6?
post #8 of 20 (permalink) Old 11-05-2011, 02:02 PM Thread Starter
alvector's Avatar
As I think more about it, could the readings sign toward out of adjustment of the carbs? Twin zeniths.
alvector is offline
post #9 of 20 (permalink) Old 11-05-2011, 02:03 PM Thread Starter
alvector's Avatar
No on the oil on plugs. All were nicely colored and clean.
alvector is offline
post #10 of 20 (permalink) Old 11-05-2011, 02:09 PM
flyboyike's Avatar
Quoted: 69 Post(s)
If you suspect the carbs, do a dry test (no fuel) and see if the difference is just as dramatic.
Low Compression - Why? quakercity W140 S-Class 6 05-13-2011 08:03 AM
Engine Compression questions - running high compression nav_bhandher W126 S,SE,SEC,SEL,SD,SDL Class 0 06-21-2007 08:34 AM
560 compression cosmo 2 W126 S,SE,SEC,SEL,SD,SDL Class 1 05-07-2007 03:05 PM
Low compression DANSMB W201 190-Class 11 03-04-2007 07:52 PM
Low compression, cyl #3 hellgrün560 W124 E,CE,D,TD Class 7 12-20-2006 09:51 PM
