76 240D master key question - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 11-01-2011, 06:49 PM Thread Starter
Date registered: Oct 2011
Can the square master key be duplicated using the VIN number. I have the round valet key only. The master key is missing so I cannot unlock the trunk unless someone can tell me how to utilize the vacuum lock system to unlock the trunk if that's even possible.
oldgreen76-240d is offline
post #2 of 7 (permalink) Old 11-02-2011, 05:05 AM
Date registered: Aug 2009
Quoted: 53 Post(s)
Yes. Take the current registration (some dealers might require the the title) and a photo I.D. to the dealer and they will order a key for you. This key will be for the ORIGINAL lock cylinder so if someone has replaced the ignition it won't work.
You might get lucky. Most of the glove box lock cylinders have all of the tumblers installed (the missing tumblers are the difference between the keys). You can pull the lock and have a locksmith cut you a key. Have them use a STEEL blank. If they can't/wont supply you with a steel key then consider it as "rainy day" use only. The soft keys are one of the best ways to bugger up an ignition lock cylinder.
Mike D is offline
post #3 of 7 (permalink) Old 11-05-2011, 10:24 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 661 Post(s)
You can also cut a new master key, using the valet as a template. The only difference is the key blank. Get your hands on a master key blank, and you're in business.
GeeS is offline
post #4 of 7 (permalink) Old 11-05-2011, 10:32 PM
Mercedes mechanic's Avatar
Date registered: Mar 2011
Vehicle: Timeship, see you yesterday, but you already knew that.
No sir, you can cut a valet key from a blank to a valet key. But just cutting a key does not make it a master. And a master key is one that will start any Mercedes (with that lock), not just his.
Master = Manufacturer
Owner = All lock's
Valet = no trunk or glove box.
If I told you, you only had to file the valet key to make it a owner key, what would you say?
Top five reasons I posted in your topic:
1. You're talking about god, there has never been any god of any kind. EVER!
2. I just have a general dislike of you.
3. I am trying to tell you how to fix your Mercedes and you are not listening.
4. I'm flirting with Jody.
5. You're just to dumb to own a Mercedes, and should go buy a Honda.
Mercedes mechanic is offline
post #5 of 7 (permalink) Old 11-05-2011, 11:35 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 661 Post(s)
The only difference between a master key and a valet is the key blank, and you can absolutely create a functional master key by cutting a master key blank, using your valet key for a template, since they have identical cuts. I should know, I have done just that literally dozens of times. Furthermore, you can easily turn a master key into a valet key, though you cannot turn a valet key into a master.
GeeS is offline
post #6 of 7 (permalink) Old 11-05-2011, 11:50 PM
Your still saying master key. Its a owner key. A master key will turn all Mercedes ignition locks.
His car has a possibility of 1296 key's. Ask me how I know that.
Is your valet key stamped with a number at all?
post #7 of 7 (permalink) Old 11-06-2011, 12:44 AM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 661 Post(s)
Are you serious? This is about semantics? Go back and see what Mercedes called the key that operates the ignition and opens the trunk 35 years ago (the age of the car in the op), if it means that much to you. Now please stop trolling the thread with this nonsense.
GeeS is offline
    75 240D Master Cylinder, Brakes, Bearings? VagusX Vintage Mercedes-Benz 1 07-07-2010 04:06 AM
    Brake Master Gromett question....... NorCalSL R/C107 SL/SLC Class 2 07-31-2007 10:36 PM
    Master brake cylinder question ccheaton W124 E,CE,D,TD Class 11 10-30-2006 07:31 AM
    DIY 240D master brake cylinder replacement? JohnMcConnell W123 E,CE,D,CD,TD,TE Class 5 12-09-2005 07:01 PM
    1979 240D Master Cylinder Price? Fannymae88 W123 E,CE,D,CD,TD,TE Class 4 07-25-2005 11:08 PM
