problems in unlocking hardtop 560 sl - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 11-01-2011, 07:33 AM Thread Starter
Date registered: Nov 2011
Unhappy problems in unlocking hardtop 560 sl
I just purchased a 1987 560 sl; I’m having troubles in removing the hardtop; The front & side catches are released; I can lift the top about an inch but it seems to be caught on the rear tang and won’t release. I can not turn the safety lever as far as instructions show. Any suggestions?Thanks
alan69 is offline
post #2 of 4 (permalink) Old 11-03-2011, 11:22 PM
Date registered: Oct 2011
Vehicle: European version 1985 280 SL
remove rear seat and rear seat back to access the latch for the center pin. Use a screwdriver to open the latch. Clean and lube all parts before reassembly and make sure that the center pin latch operates freely before reinstalling the top
m110 is offline
post #3 of 4 (permalink) Old 11-04-2011, 08:18 AM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
You may want to go over to the 107 forum, it's very active, and there are a lot of people that have had the same sort of rpoblem. They'll be able to ask the right questions and give you the right procedures to get the top working again. There are a couple of things that can get out of adjustment that they'll be able to point you at.
Good Luck
RadioTek is offline
post #4 of 4 (permalink) Old 11-04-2011, 09:56 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
What rear seat?
flyboyike is offline
    HELP!! Door locking-Unlocking problems! soonsuh W211 E-Class 3 08-08-2009 11:10 PM
    manually unlocking hardtop joesiegel R129 SL-Class 10 01-02-2009 10:26 AM
    1993 500SL Hardtop Problems JAYSONBENZ R129 SL-Class 3 09-03-2008 01:45 PM
    Problems with hardtop zlaja230 R170 SLK-Class 4 04-20-2008 05:15 PM
    Hardtop removal problems limpdude87 R/C107 SL/SLC Class 9 09-29-2004 11:31 AM
