ID help - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 10-28-2011, 07:15 PM Thread Starter
Date registered: Jan 2007
Vehicle: 91 300 TE 4matic 86 Jag XJ6 88 Camry Wagon 77 F350
ID help
Any help id on this car?
69 280s?
Pic o0nly, supposed 6 cyl dual carb.
Thanks. Tom
msteelsos is offline
post #2 of 7 (permalink) Old 10-28-2011, 07:25 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
69 280s?
Thanks. Tom
Don't see a pic.
flyboyike is offline
post #3 of 7 (permalink) Old 10-28-2011, 09:44 PM
wbain's Avatar
Date registered: Dec 2003
How about a specific question. Some location info and current car info would be helpful, like on mine.
wbain is offline
post #4 of 7 (permalink) Old 10-29-2011, 06:27 AM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
1969 280S, 6cyl, overhead cam designated as M130 engine. 2 dual downdraft ZENITH carbs 35/40 NAT. 25,249 units made in 1969, total units 93,665 from 1967-1972. Top speed 112 mph and 18.75 mpg. 157 hp. Weak points are rust above the headlights and failing automatic transmission at 200,000 miles.
Ed Mclass is offline
post #5 of 7 (permalink) Old 10-29-2011, 10:36 AM Thread Starter
Didn.t mean to post that yet
Now thinking 220/230
Supposedly running, guy died, parked for 15 yrs.
6 cyl, dual carb, auto.
No vin till I go to see it tomorrow.
post #6 of 7 (permalink) Old 10-29-2011, 11:33 AM
flyboyike's Avatar
Quoted: 68 Post(s)
Probably 250 then.
post #7 of 7 (permalink) Old 10-29-2011, 01:26 PM Thread Starter
Sitting in southwest New Mexico, which is a good mothball area,
Rubber and associated seals usually affected first.
$2-300 asked.
Usually pull plugs, squirt oil in cylinders and crank on the long unused engines (after oil and water check).
Then try a little fire and fuel.
Are auto trans kits available?
Ze carbs?
Any advice?
Thanks,
Tom
