1976 280 Sedan... (quick question for ya) - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-26-2011, 08:03 PM Thread Starter
BlueSkiesWhiteClouds's Avatar
Date registered: May 2011
I have a 1976 280 sedan 6 cyl with the single Solexcarb..I use this 280 as my everyday vehicle. I have been very fortunate and have not experienced any big issues....I was wondering if someone could possibly diagnose or share some knowledge on a cold start problem I often experience.???
The car startson the second or third crank sequence. At that point it slowly warms itself. After a few minutes i'll drive away and the car will almost stall...sputter a bit.. then pick up...Stop sign stutters, almost will not move with accelerator pressed lightly..(if you press the accelerator too hard or quickly the car will sputter and die..)
Afte about 10 minutes of driving, she runs pretty well.No more stalling..This only happens after sitting and becoming cold... (like over night).Could this be timing issues? Do I need new plugs n wires?? Any suggestions would be greatly appreciated..
Thank you in advance
Name:	1976 Mercedes Benz 280 4 dr 011.jpg
ID:	405918   Click image for larger version
Name:	1976 Mercedes Benz 280 4 dr 001.jpg
BlueSkiesWhiteClouds is offline
post #2 of 4 (permalink) Old 10-27-2011, 04:51 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
When was the last tuneup and/or carb cleaning? How old is the fuel filter?
flyboyike is offline
post #3 of 4 (permalink) Old 11-01-2011, 07:58 AM
ollo's Avatar
Date registered: May 2009
Vehicle: S430 93K; E420 243K; 240D 242K
Quoted: 65 Post(s)
I had a 73 280 and my only experience of these symptoms was cured by replacing the fuel filter(once), rebuilding the carburetor (a few years later) and a much later rebuild of the vacuum pump that was driven by the driver side cam on my 110 engine. I don't know if they still used that vacuum pump on your engine as there was none on the 76 280 S with same engine that we later owned.
ollo is offline
post #4 of 4 (permalink) Old 11-01-2011, 09:24 AM
Check the choke for closing and proper opening when warming up.
Put your hand on the thermostat housing to
sense warm-up and thermostat operation.
Brian O
bostosh is offline
    QUICK wiring question for 99 500 sedan... PKariCL600 W140 S-Class 2 06-03-2011 11:17 PM
    FS 1976 300D - 4 door sedan jbenoit For Sale/Wanted/Trade/Giveaway 4 11-16-2010 12:23 PM
    Quick universal question and I need quick answare ADRIAN126sec W140 S-Class 2 06-25-2010 10:22 PM
    WTB 1974-1976 w115 230 Sedan andrewcconti For Sale/Wanted/Trade/Giveaway 0 09-25-2008 01:15 PM
    1976 Mercedes 240D Sedan - 4 speed theob For Sale/Wanted/Trade/Giveaway 0 01-06-2008 07:24 AM
