1974 280 - New Thread - Page 2 - Mercedes-Benz Forum
post #11 of 11 (permalink) Old 12-13-2011, 02:26 PM
Date registered: Dec 2011
I'm new here so forgive me if I have posted this in the wrong forum. If possible, please help:
My 1974 Merc 280 had a problem starting the other day following lots of rain. The next day it started right up and then stalled after a minute. I thought it was an electrical issue so I gave it a new distributor cap, rotor, plugs and wires as well as a new air filter as the old one seemed to have melted a bit. After changing all that it started and ran like a champ until I tried to drive away. It backfired through the carb and stalled. Since then I have gotten it to start again and run for about a minute then it suddenly cuts out as if I turned the key off. Occasionally it will bog down and I can keep it running for a bit by giving it gas but it still stalls in the end. After stalling it needs to rest for a few minutes before it will start again. The choke and carb intake were sticky so I sprayed them with carb cleaner and they seem to be moving fine now. I'm at a loss for what to try next; thinking fuel filter, fuel pump relay, points, coil, carberateur???? Any suggestions would be greatly appreciated, I don't want to have to put it in the graveyard. Thanks in advance.
PS. I have the same shifting problem mentioned by ward in the beginning of this thread... what was the fix?
USA 1974 280 is offline
    Do It Yourself (DIY) repair thread and wheel and tyre thread Dr.Grillz W126 S,SE,SEC,SEL,SD,SDL Class 217 09-10-2016 01:20 AM
    Naked girls thread...18+ yrs old to enter this thread. KamiL Off-Topic 125 12-06-2013 12:28 AM
    Marshcat's 1974 450SL Fix-Up Thread marshcat R/C107 SL/SLC Class 13 05-20-2013 11:55 AM
    Not another WHEEL thread, but a SPACER thread Kalifornia W126 S,SE,SEC,SEL,SD,SDL Class 7 07-30-2006 02:06 AM
    Interesting thread regarding using the OBD II port. Periokid, you might want to read this thread... SteveL R170 SLK-Class 2 04-30-2002 01:29 PM
