Doing a Battery Relocation to the trunk or under the rear seat. - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 11-22-2011, 12:44 AM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 33 Post(s)
I didn't put any fuse or relay in, as it didn't have one in there originally. I only put a master switch in so I can disconnect the battery easily rather than having to open the plastic box up.
I used both methods - I crimped the main wire as it was already in place and I was told that would be ok. But I needed some extra lugs, so popped into an auto sparkies shop to get some. He soldered on 4 lugs for me for about $10 from memory. He used a blowtorch to heat up the cable.
I must say, the condition of your red seats is remarkable compared to the engine bay... Are they from the same car?!
drew56cus is offline
post #12 of 16 (permalink) Old 11-22-2011, 04:49 PM Thread Starter
QuickSilver2's Avatar
Date registered: Oct 2007
Vehicle: 1992 190e 2.6
Originally Posted by wbain View Post
I love those red seats.
They are scrumptious and one of the reasons that I bought a Mercedes with no engine
QuickSilver2 is offline
post #13 of 16 (permalink) Old 11-22-2011, 04:51 PM Thread Starter
Yes same car.
To be honest, even though I was shopping for a project, I wasn't thinking about an old Mercedes. Once I saw the condition of the interior, the body work, the wood stuff I knew I had to save the car from the wreckers.
So I tried my hands at soldering last night.
Not bad for a daytime computer Guy eh
post #14 of 16 (permalink) Old 11-25-2011, 04:35 PM Thread Starter
Whats a good location to bolt the negative cable into in the trunk?
post #15 of 16 (permalink) Old 11-25-2011, 11:47 PM
drew56cus's Avatar
Quoted: 33 Post(s)
You can see where I did mine on the previous page - look at the closest end of the battery box and you will see the -ve cable coming out and bolted to the seam of the boot- there happened to be a hole right near the battery.
post #16 of 16 (permalink) Old 11-26-2011, 09:29 AM Thread Starter
Thanks Drew, I was overthinking it as usual.
I popped into the garage this morning and finished it up.
Happy to announce no meltdowns, no smokes out of the wires, etc
I will splice in a fuse at some point but for now it's finito. Now onto the brake system.
Thanks for all your help and others too.
    Battery relocation robst3 W123 E,CE,D,CD,TD,TE Class 11 10-06-2011 07:06 AM
    84 500 SEL - Can't open trunk, or remove rear seat Nitro88 W126 S,SE,SEC,SEL,SD,SDL Class 32 02-12-2011 03:53 PM
    Where to Buy Trunk (AUX) Battery M_city R230 SL-Class 1 04-18-2009 12:35 AM
    Battery relocation to bed ? atom Unimog 5 01-20-2008 06:29 PM
    routing cable from battery to trunk and from trunk to console ganesh R170 SLK-Class 0 05-28-2006 11:17 AM
