Universal Door Seal / Weather Stripping? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-17-2011, 12:32 PM Thread Starter
Flofloyd's Avatar
Date registered: Aug 2010
Vehicle: 300TD
I tried searching for a thread on this subject, but didn't find one.
I drive a 1979 300TD and when it rains there is a LOT of water on the passenger side of the car. ((floor)) I'm pretty sure it's from the bad stripping on the passenger/front door; there's a sizable crack in it. And it's running down the pillar with the seatbelt and onto the floor. YIKES.
I know 3M and a few other companies make a universal door seal/weather stripping that is a lot cheaper than an original replacement. Is this okay or will this not work?
Thanks!
Flofloyd is offline
post #2 of 5 (permalink) Old 10-18-2011, 10:58 PM
Date registered: Mar 2011
Vehicle: 1971 250/8 sedan with 80 K miles. Driven only in Summer.
I would check the well under your windshild first. It should drain quit easily. On a dry day pour a bucket of water down your windshield. The two drainholes could be plugged with dirt. On your cracked seal , I would try some black contact cement to seal the crack.
Over 75 is offline
post #3 of 5 (permalink) Old 10-19-2011, 06:16 AM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
Post Plugged drain hose
I had 5 of these wagons and it is more possible that the hose is plugged up. You can still get the weather stripping from your dealer.
Ed Mclass is offline
post #4 of 5 (permalink) Old 10-19-2011, 06:35 AM
Date registered: Sep 2008
Vehicle: 1996 E320, 2005 Toyota Camry
Quoted: 96 Post(s)
water
Which hose?
Hemersam
Beverly Sharp is offline
post #5 of 5 (permalink) Old 10-19-2011, 07:04 PM
The gutter under your windshield has drainholes connected to rubber hoses. you have to clean those.
Over 75 is offline
    How do you clean the inside door weather stripping? MAVA Detailing and Car Care 5 05-19-2011 06:03 PM
    Weather Stripping- Fortify Door Seal/noise TheGodfather W163 M-Class 4 06-28-2007 10:48 AM
    weather stripping black cloud W123 E,CE,D,CD,TD,TE Class 4 09-23-2005 08:29 AM
    Weather Stripping Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 1 05-01-2004 02:11 AM
    Rear door window weather seal mombaza W163 M-Class 2 08-20-2003 09:33 PM
