Question On Domestic Engine Swap Into W108 - Page 3 - Mercedes-Benz Forum
post #21 of 53 (permalink) Old 10-21-2011, 08:47 PM Thread Starter
QuickSilver2's Avatar
Date registered: Oct 2007
Vehicle: 1992 190e 2.6
Thanks Pete.
Here is my lowly Mazda B2000 turned B5000
Many unsuspecting victims were left at stoplights wondering what just happened -
Here's an MGB I was working on
No pictures of my old 914 with the Chevy 454.
The only thing I've seen so far that could cause an issue is that the tunnel is narrow in the W108, I like how GGR grafted part of a new tunnel in his swap.
I can't wait till daybreak here so I can hit the junkyard.
QuickSilver2 is offline
post #22 of 53 (permalink) Old 10-21-2011, 09:54 PM
Rupununipete's Avatar
Date registered: Sep 2011
Vehicle: 1992 600 SEL x 3, 1998 E430 x 2
Quoted: 81 Post(s)
Ha ha ha... you put a grin on my face.
To quote Hunter S. Thompson... "when the going gets wierd, the weird turn pro"
You are obviously the man for the job on this small block swap into your Mercedes.
Pete
Rupununipete is offline
post #23 of 53 (permalink) Old 10-23-2011, 05:53 AM
Date registered: Jan 2006
Vehicle: 1996 W210 E320 ELEGANCE, 1972 W108 280SE 3.5, 1969 W108 280S, 1971 300SEL 3.5
About 15 years ago I did this exact swap into my 1969 280SE using a SB chev and a T350 trans, but if I am to do it again (and I am ;P ) I would use a injected 5.0 from a Mustang.
If you look up Castlemain Rod Shop ( Castlemaine Rod Shop ) and click on the link to Mercedes Benz, they have a selection of engine & gearbox mounts/adaptors to suit various motors, Ford Windsor and Cleveland as well as SB chev.
I hoped this helped.
GANSTA is offline
post #24 of 53 (permalink) Old 10-23-2011, 09:50 AM Thread Starter
This information is exactly what I've been looking for.
Thank you Sir.
post #25 of 53 (permalink) Old 10-23-2011, 01:43 PM
Date registered: Jan 2007
Some where in my "stash" I have an "Engine Swap Guide" from the late 70's, or early 80's. There is an illustrated article on swapping a Chevy SB into a 108. Here is what I recall. They used a Turbo 350 tranny which fit easily. Today, it would seem silly not to use a overdrive automatic. This bolted right up to the MB drive shaft. To avoid the oil sump problem they used a pick up and pan from a '62 Nova V-8. That moves the sump and was a standard "hot rod" trick in the day. I believe that pan is still produced in the after market.
I will try to find it, scan it and post it. If nothing in a week, remind me.
TFaust is offline
post #26 of 53 (permalink) Old 10-23-2011, 03:59 PM Thread Starter
Thank you, I would be eternally grateful.
post #27 of 53 (permalink) Old 10-24-2011, 07:01 PM Thread Starter
Here is the result of my home work assignment:
"I cannot be too sure if the mounts will suit your particular car being a left hand drive where as they were more designed for our right hand drive model W108" Per Rods.
Unfortunately this leads to another question thus, is there an engine bay difference between LHD and RHD when it comes to engine mounts?
post #28 of 53 (permalink) Old 10-25-2011, 04:07 AM
I think the main difference would be where the steering and brake componants ar located in the engine bay, looking at both of my 108's, one is a 6cyl and the other is a 3.5 V8, the engines appear to locate in the center with no visible lean in either direction. Think the biggest heardle you might face will be the headers.
GANSTA is offline
post #29 of 53 (permalink) Old 10-26-2011, 11:32 AM
Mr Quick,
I looked at Ingrid's site and must say after experiencing torque monster engines, (426 Hemi, 6.3MBZ)
Think about the lack of torque of a 302 Vs the weight of the W108 chassis.
The difference of a 302 and a Cleveland 4V is a
lot.
I did a 302 once and yanked it rather quick.
Brian O
bostosh is offline
post #30 of 53 (permalink) Old 10-26-2011, 12:43 PM Thread Starter
Hey Brian:
Here's my thinking, and please correct me as you have first hand experience.
A basic 302 should have more power than the original 250 right?
So if I start with that then I can do heads, supercharger and as such later.
I do recognize where you are coming from and I am listening.
    HELP engine swap question e320help W210 E50 AMG, E55 AMG 1 09-06-2011 11:59 PM
    engine swap question hyperboost W126 S,SE,SEC,SEL,SD,SDL Class 0 01-13-2010 10:28 AM
    Engine Swap W108 280S to 300D Diesel pookybbb Vintage Mercedes-Benz 3 09-20-2009 09:59 AM
    Engine Swap Question????? capitolj Vintage Mercedes-Benz 5 02-06-2009 04:36 AM
    W108 engine swap? Danborn Vintage Mercedes-Benz 1 07-07-2005 07:15 AM
