'76 300d transmission issue... - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-16-2011, 06:07 AM Thread Starter
Date registered: Mar 2011
So i recently changed the ATF and filter in the auto tranny on my 76 w115 300d....which i was recently told was not a very good idea...and recently i would be cruising at about 30-40 mph and the engine would start revving as though my left foot was accidentally depressing the clutch...only there is no clutch as its an auto...the guy i spoke with who said changing the fluid was a bad idea suggested adding a bottle or two of Lucas transmission fix...a much heavier weight ATF...can't say i've noticed an improvement.....
just wondering if any of you out there have any advice on what the problem could be or if any of you have been in the same situation?
ianfotheringham is offline
post #2 of 3 (permalink) Old 10-16-2011, 06:52 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Does it do that all the time or is it intermittent?
flyboyike is offline
post #3 of 3 (permalink) Old 10-16-2011, 06:54 AM Thread Starter
its intermittent - and usually only in the first few miles once started from cold....then goes away....till the next morning...
    1983 300D New Transmission electronic connector issue Billynok W123 E,CE,D,CD,TD,TE Class 1 05-04-2011 12:47 PM
    Will this 79 300D Wagon transmission fit my 81 300D Sedan? sshanky W123 E,CE,D,CD,TD,TE Class 0 12-16-2010 11:37 PM
    Starting issue 85 300D DAP W123 E,CE,D,CD,TD,TE Class 62 05-09-2009 05:18 PM
    Shifting issue in my 76 300D matthend Vintage Mercedes-Benz 1 02-26-2005 05:31 AM
    300D Transmission Issue Joey W123 E,CE,D,CD,TD,TE Class 2 01-08-2004 08:30 PM
