Can you ID this axle and/or these brakes? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 10-15-2011, 12:33 PM Thread Starter
Rukh's Avatar
Date registered: Aug 2011
Vehicle: '66 Mercedes 230S
Need help identifying this axle. At some point in its surely-interesting life, my W111 230S was retrofitted with a non-standard rear axle and its drum brakes. Now I need to order shoes and wheel cylinders for my mechanic, but he's not sure from what car this axle came. Any help would be appreciated, TIA.
Rukh is offline
post #2 of 11 (permalink) Old 10-15-2011, 06:39 PM
wbain's Avatar
Date registered: Dec 2003
It looks standard to me. The 111.010 230S came with a swing axle with rear drums. The only things that look odd are the twin exhaust system and the horizontal coil in the middle. I think it came with the hydropneumatic compensator. I could be wrong on the last part.
wbain is offline
post #3 of 11 (permalink) Old 10-15-2011, 09:21 PM Thread Starter
Rukh's Avatar
The exhaust is definitely not standard - the PO had a custom exhaust made, and then had the guys put twin glasspacks on it. :-(
Rukh is offline
post #4 of 11 (permalink) Old 10-16-2011, 05:06 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
I agree, the axle looks stock to me.
flyboyike is offline
post #5 of 11 (permalink) Old 10-16-2011, 09:19 AM
wbain's Avatar
Please make sure you grease the two zerk fittings on the swing axle joint. Then there are all the grease fittings on the front suspension.
wbain is offline
post #6 of 11 (permalink) Old 10-16-2011, 10:06 AM Thread Starter
Rukh's Avatar
Alright, thanks for the help guys. I'll have my guy get on the parts for the brakes. Any guesses on where to check for that compensator, if that's the case, for the swing axle?
Rukh is offline
post #7 of 11 (permalink) Old 10-16-2011, 02:40 PM
wbain's Avatar
You're better off with the spring. The others are VERY expensive.
wbain is offline
post #8 of 11 (permalink) Old 10-16-2011, 03:18 PM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 36 Post(s)
From what I've read, people report no difference in the ride between the spring and the hydropneumatic. I've never seen a car with a swing axle that hasn't had the hydropneumatic eventually replaced with a spring.
With regard to the brake cylinders, they are very expensive purchased new (around $180 each). The good news is that rebuild kits can reportedly be purchased at a regular parts store. The bores are standard sized and are the same as some older American cars. I believe there are two bore sizes. Have your mechanic measure the bore and head on down to the parts store. Ebay often has rebuild kits for sale, as well.
The shoes are extremely hard to find new, and I expect ridiculously expensive. Most folks send them out to be relined.
EDIT: I was reading the Heckflosse site and apparently the hydro cylinder was an option on the fintails.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #9 of 11 (permalink) Old 10-16-2011, 10:02 PM Thread Starter
Rukh's Avatar
Well, I was looking at these shoes: AutohausAZ $26.71, but then I realized that it appears to only be parking brake components. Maybe? I don't know - is it common to have a drum-type parking brake on rear disc-brake equipped cars? How does that work?
I found these wheel cylinders too, at the same site: AutohausAZ $60.70. Thoughts?
All in all, I love old cars, and I love MY old car - but I am smart enough to know what I don't know. So I ask the experts...
Rukh is offline
post #10 of 11 (permalink) Old 10-16-2011, 10:12 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 103 Post(s)
Yes - my 108 has the same setup.
Grubeguy is offline
    What tool do I need to remove the 8 axle bolts connecting axle to the differential? springsman W124 E,CE,D,TD Class 11 06-27-2012 05:45 AM
    pinion and gear of rear axle in the front axle on a 460? ignacio_antoine G-Class 1 06-11-2011 10:16 PM
    Right Front Axle Shaft Disconnected from Front Axle Gear chiman0101 W164 M-Class 2 05-10-2011 05:48 AM
    Rear Axle Bearing Rotating in Axle-Housing fernweh G-Class 11 12-19-2005 11:59 AM
    Axle/Axle Parts for Sale Gollygwagen G-Class 9 10-15-2002 09:37 AM
