Can you ID this axle and/or these brakes? - Page 2 - Mercedes-Benz Forum
post #11 of 11 (permalink) Old 10-16-2011, 10:16 PM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 33 Post(s)
Yes, Mercedes uses drum-type parking brake shoes on their rear disc brake systems. The rotor has an integral drum and the shoes work just like a regular drum system except they are actuated by a cable. You don't want those.
That's a decent price for the cylinders, certainly better than the price I was quoted for the OEM part. You notice that they specify a "later type" bore size. Measure your old cylinders before you order them just to be sure they are correct.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
    What tool do I need to remove the 8 axle bolts connecting axle to the differential? springsman W124 E,CE,D,TD Class 11 06-27-2012 05:45 AM
    pinion and gear of rear axle in the front axle on a 460? ignacio_antoine G-Class 1 06-11-2011 10:16 PM
    Right Front Axle Shaft Disconnected from Front Axle Gear chiman0101 W164 M-Class 2 05-10-2011 05:48 AM
    Rear Axle Bearing Rotating in Axle-Housing fernweh G-Class 11 12-19-2005 11:59 AM
    Axle/Axle Parts for Sale Gollygwagen G-Class 9 10-15-2002 09:37 AM
