Sls valve not working? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-14-2011, 05:42 PM Thread Starter
Date registered: Oct 2011
Hi, I have a w123 wagon that I just got. The back sags like crazy and it is apparent that the self leveling suspension is not working. The pump seems to work because fluid is being returned to the reservoir but in a steady stream not very fast. The valve was disconnected from the sway bar and when I tried to operate it by hand it moved freely and didnt move the shocks up or down. The valve did not give any resistance. I am ordering the necessary components to attach the valve lever back to the sway bar. What should I do next? Thanks in advance. - jim
huck finns buddy jim is offline
post #2 of 2 (permalink) Old 10-15-2011, 04:25 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Check the accumulators, they probably failed first, and everything else followed. Fortunately, they're relatively inexpensive.
Your Parts Search Returned 1 Part(s)
Also, see our W123 forum for gobs and gobs of knowledge on this and many other issues.
flyboyike is offline
    question on air check valve/ shut off valve shaunt R170 SLK-Class 6 12-29-2010 01:08 AM
    Where can I buy a working VCV valve?? BioNerd W123 E,CE,D,CD,TD,TE Class 1 11-13-2010 08:25 AM
    Idle control valve/air slide valve question dcrews R/C107 SL/SLC Class 5 05-24-2010 01:54 AM
    Working without a manual this weekend: front brakes / valve cover gasket. Any suggestions? 71Rcode W124 E,CE,D,TD Class 9 03-07-2004 07:30 AM
    Idle valve = Cold Start Valve ? maxhofer W123 E,CE,D,CD,TD,TE Class 1 01-27-2003 01:26 AM
