Solex PAAI 30 carburator cold start issues - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-13-2011, 06:28 PM Thread Starter
Rupununipete's Avatar
Date registered: Sep 2011
Vehicle: 1992 600 SEL x 3, 1998 E430 x 2
Quoted: 84 Post(s)
I have a 1952 220 sedan that is giving me issues with cold starting as the cold start circuit plunger assist just doesn't. The plunger, if engaged, causes the engine to die once running and air intake can be heard after engagement just before it shuts down.
Once the car is started and warms up it runs like a swiss watch. I have installed a rebuild kit and resolved a minor vacuum leak by cutting a gasket for between the throttle plate body and carburator casting using very thin gasket stock, but cannot figure out why the cold start circuit will not funtion.
Thanks
Pete
Rupununipete is offline
post #2 of 4 (permalink) Old 07-05-2012, 07:46 PM Thread Starter
Quoted: 84 Post(s)
Well, hmmm, to answer my own thread...
There was a casting flaw in the carburator bowl as shown in the attached images. Third time apart was the charmer, after carefully checking idle speed increase with propane. There was the ever so slight increase when near this corner of the carb. So slight I almost thought I imagined it.
I built it up with an aviation metal epoxy called "MetalSet" and all is well. This must have been an issue since day one. Might be parts of the reason the car is in such excellent low mileage condition.
Pete
Name:	IMG_2761 paint.jpg
ID:	454277   Click image for larger version
post #3 of 4 (permalink) Old 07-06-2012, 08:40 AM
NorCalSL's Avatar
Date registered: Jun 2007
Vehicle: '70 280S-'73 450SLC-'81 380SL-'84 500SEC Euro-'92 300SL24-'95 E320
Quoted: 22 Post(s)
Very unusual indeed, good find. Now, where are the pics of the car?
dws
1973 Mercedes 450SLC (PineGreen/MahoganyLeather)
1981 Mercedes 380SL FORSALE (LtIvory/PalominoMBTex)
1984 Mercedes 500SEC Euro (040Black/BlackLeather)
1992 Mercedes 300SL-24 Signal Red/Black Leather
NorCalSL is offline
post #4 of 4 (permalink) Old 07-06-2012, 08:48 AM Thread Starter
Quoted: 84 Post(s)
Images of '52 W187
dws
Here you go...
ID:	454343   Click image for larger version
Cold start issues guinter810 W201 190-Class 2 03-31-2011 06:23 PM
cold start issues 500 sec Auto-Retro W126 S,SE,SEC,SEL,SD,SDL Class 2 02-20-2011 03:25 PM
Cold start issues 84 bioburner W123 E,CE,D,CD,TD,TE Class 2 01-16-2008 11:45 AM
07 cold start issues? Anyone experienced this? bebbmi W203 C-Class 18 03-15-2007 10:19 AM
300 sel cold start issues Dusty`NZ W126 S,SE,SEC,SEL,SD,SDL Class 2 08-26-2005 09:57 PM
