help with w115 wiper foot pump trouble shooting - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-12-2011, 11:47 PM Thread Starter
Vehicle: 84 280GE
Hi,
I'm trying to figure out why my water jets aren't working on my 115.117.
the pump appears to pump, the tank looks great.
I see a white little manifold on the firewall that could be a check valve.
if that's what it is, then I suspect it's the culprit. as the bottom inlet appears to be blocked in either direction of pressure.
is this something I should just poke at til it works? I just did some searching and couldn't find a source for a new one.
syncro is offline
post #2 of 3 (permalink) Old 10-13-2011, 05:27 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
The water jet system works with a foot pump, a valve on top of the water reservoir and a check valve in the tube to the water jets, to prevent the system from draining.
If you disconnect the tube to the jets, and pump the foot pump, it should pump water. Than the check valve is the culprit. You can try poking it, but it can also be replaced, it is not that expensive.
Govert70227 is offline
post #3 of 3 (permalink) Old 10-13-2011, 10:28 PM Thread Starter
Vehicle: 84 280GE
Thanks, I just priced it out a classic center. It's cheap enough to add to my door seal order.
syncro is offline
Need some trouble shooting help. Herbie3Rivers W123 E,CE,D,CD,TD,TE Class 5 01-14-2010 05:34 PM
Trouble shooting ABC/Pwr Steering rtgogo C215 CL-Class 10 12-13-2009 03:57 PM
Help trouble shooting Low Range silver Inspiration W163 M-Class 6 10-06-2009 08:11 AM
404 Gas Tank Trouble Shooting raabta01 Unimog 9 04-25-2007 11:26 AM
trouble-shooting PART II nobby R/C107 SL/SLC Class 15 02-19-2006 11:21 AM
