Is this a D Jetronic idle air valve problem? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-11-2011, 01:05 PM Thread Starter
Date registered: Oct 2011
Trying to fix a no cold idle on a 71 W114 280CE with M110 and D Jetronic. Looking at all the great D Jetronic information on the site, the fault would appear to be with the thermal expansion activated idle aux air valve.
1. No problems starting
2. No idle when cold, but ok with throttle just a little open
3. Tick over fine one normal temp reached.
The valve when cold seems to be stuck open and supplying air around the flap valve - which is what I hough to be correct. I am expecting the valve to close when normal temp is reached so only air path is through the throttle flap valve
Checked by removing air pipe from the valve to the inlet manifold and blocking this up so there is no aux air supply, and engine idles perfectly when cold, and also compensates when auto is moved in to drive.
So should the valve be open when cold, and close when hot, and I am chasing the wrong fault?
The valve is deep down on the side of the engine under the manifold, and not easy to get to from either top or bottom, so hauling it out is going to be difficult, and I am loosing sleep trying to figure this out!
Dombert03 is offline
post #2 of 4 (permalink) Old 10-15-2011, 11:40 AM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
The AAV on a D-Jet system is supposed to be open at cold, closed at hot(engine temp), just like you guessed. But don't get fixed on the AAV, there are plenty of other pieces that could cause your trouble. I chased dirty breaker points for better than a month one time..
RadioTek is offline
post #3 of 4 (permalink) Old 10-17-2011, 04:33 AM
unimoged's Avatar
Date registered: Dec 2008
Vehicle: 2004 S500. 2000 CLK430 Cab, 1999 C43 AMG. 1999 S500. 1999 S320. 1977 230 4 spd, 1972 280SEL 4.5
Use a DVOM and see if your cold start injector is working at start-up. If the valve is open, it only supplies air and without the injector supplying fuel, you will not have fast idle when cold.
unimoged is offline
post #4 of 4 (permalink) Old 10-17-2011, 07:25 AM Thread Starter
Thanks for your help and confirming things are currently working backwards!
Certainly didn't want to have to sort out the AAV if I didn't have to - looks to be designed to be an engine out job! Given ignition a quick visual, but I don't think it has been touched for a long time, so would be good practice to go through this anyway.
With the DVOM, what should I be looking for? I take it that The DVOM will tell if the injector getting a switch signal, but should I also remove the injector and check for fuel spray as well when cold in case this has become blocked?
Feedback much appreciated.
    Testing Idle Valve - High Idle Problem Jonathan Laws W126 S,SE,SEC,SEL,SD,SDL Class 16 08-11-2012 05:55 AM
    D Jetronic Idle Air Valve Dombert03 General Mercedes-Benz 0 10-11-2011 09:15 AM
    Idle air control valve problem yonsquire W201 190-Class 1 01-01-2010 07:49 PM
    idle control valve problem? turtle W124 E,CE,D,TD Class 0 08-26-2005 03:07 PM
    380 SEL Idle Valve Problem-Is it SAFE to Drive??? Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 3 07-25-2002 08:08 PM
