1978 240D sedan - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 10-04-2011, 03:53 PM Thread Starter
Date registered: Oct 2011
Vehicle: 1978 240D Bio/WVO
1978 240D sedan
Got a 1978 240D sedan that has been running well but now the clutch is sticking to the floor occasionally (I have to lift it up with my foot) and has become very difficult if not impossible to downshift into 2nd if the car is going anything above 15-20 mph. This has been a problem for a couple weeks and seems to be getting worse. Any advice on a diagnosis? Planning on reading my Chilton tonight to get ideas.
Bthedinger is offline
post #2 of 8 (permalink) Old 10-04-2011, 03:55 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
Generally speaking, a clutch not working properly is a symptom of a failing clutch. I hope that helps.
flyboyike is offline
post #3 of 8 (permalink) Old 10-04-2011, 04:27 PM Thread Starter
Maybe I need to be more specific. I understand that the clutch problem represents a failing clutch. But do you think the clutch is also responsible for the inability to normally shift into 2nd while at appropriate speeds. That seems like a problem with the gears or gear selector in the tramismission? Any more specific advice?
post #4 of 8 (permalink) Old 10-04-2011, 06:15 PM
flyboyike's Avatar
Quoted: 68 Post(s)
Well, yes, a worn throwout bearing would contribute to shifting difficulties. How many miles on the car and was the clutch ever serviced before?
post #5 of 8 (permalink) Old 10-05-2011, 02:28 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
This might be failing clutch hydraulics. Check the clutch cylinders first.
Also the 1978 240D is a W123 which has its own subforum:
W123 E,CE,D,CD,TD,TE Class - Benzworld.org - Mercedes-Benz Discussion Forum
Govert70227 is offline
post #6 of 8 (permalink) Old 10-05-2011, 06:40 PM
frankflynn's Avatar
Date registered: Feb 2011
Vehicle: 1973 220D
Quoted: 2 Post(s)
Yes, check the master and slave cylinders first. Then you may have to replace the clutch. But trouble going into gear in a classic symptom of a failing clutch.
Good luck
Frank Flynn. Poet, Artist & Mystic
Frank Flynn
'73 220D
'88 300SEL
'91 300TE
frankflynn is offline
post #7 of 8 (permalink) Old 10-06-2011, 12:08 AM
Quoted: 4 Post(s)
It is also a symptom of failing clutch cylinders.
post #8 of 8 (permalink) Old 10-06-2011, 12:23 AM
BioNerd's Avatar
Date registered: Oct 2010
Vehicle: 1981 300D with a funny tranny
Quoted: 5 Post(s)
I would start assuming lack of care from the PO, it seems that manual trannys cylinders are the first thing to go. I have heard that 2nd gear issue from Xo before, if I'm remembering well. PM dieselkraut. Lets make the w123 messiahs show up in oaktown
-Carlos CMT and a 1981 300D, "carmelito"
Having transmission problems? Click here for information, DIY diagnose and adjustment help
annual BAY AREA W123 BBQ - slideshow
WANTED
- rear power regulators
BioNerd is offline
    Parting 1978 240D bfinley For Sale/Wanted/Trade/Giveaway 13 02-07-2016 08:27 PM
    Feeler for parting out 1978 240D sedan bfinley For Sale/Wanted/Trade/Giveaway 1 11-20-2010 04:17 AM
    1978 Mercedes 300D diesel sedan - $600 P4olom W123 E,CE,D,CD,TD,TE Class 6 04-03-2007 08:47 PM
    1978 240d elroythekid W123 E,CE,D,CD,TD,TE Class 1 09-07-2005 07:59 PM
    Best classifieds, MB 240D 1978 newbenzowner Vintage Mercedes-Benz 3 08-01-2004 10:37 AM
