my 66 and maintaining speed on highway - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 10-03-2011, 07:55 AM Thread Starter
Date registered: Oct 2011
Vehicle: Two Tone Blue and White 1966 Mercedes Benz 200 Sedan
Send a message via AIM to briantsosie
Question my 66 and maintaining speed on highway
I just bought a 1996 mercedes benz sedan. I am having trouble on the highway. The first 15 miles are great, but then I start feeling loss of power while trying to maintain speed. I have the pedal down, but the power comes in surges. Does anyone have any idea what I need to replace? I am new to this, any suggestion would help. Thank you so much.
briantsosie is offline
post #2 of 10 (permalink) Old 10-03-2011, 09:28 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 130 Post(s)
I would try replacing the fuel filter.
Scoot is offline
post #3 of 10 (permalink) Old 10-03-2011, 01:36 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 70 Post(s)
Gas or diesel?
flyboyike is offline
post #4 of 10 (permalink) Old 10-03-2011, 01:38 PM Thread Starter
its regular gas. 200
post #5 of 10 (permalink) Old 10-03-2011, 01:43 PM
flyboyike's Avatar
Quoted: 70 Post(s)
Then I would agree with Scoot, start with the easy stuff like the fuel filter. When was the last tuneup, any idea?
post #6 of 10 (permalink) Old 10-03-2011, 01:47 PM Thread Starter
i have paperwork somewhere, but i just got it this week. i made an appointment to have it looked at tomorrow. thanks guys, ill keep ya posted.
post #7 of 10 (permalink) Old 10-03-2011, 01:51 PM
flyboyike's Avatar
Quoted: 70 Post(s)
It's always a good idea, especially with a car that old, to do a comprehensive service (all fluids, all filters, plugs, wires, cap, rotor, thorough carb cleaning, brake bleed etc) just so you can be sure what is good. Then if the car still has issues, you can eliminate a whole bunch of suspects.
post #8 of 10 (permalink) Old 10-03-2011, 04:26 PM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 37 Post(s)
If a new filter doesn't clear it up, I'd check the tank screen, then the fuel pump.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #9 of 10 (permalink) Old 01-12-2012, 06:48 PM Thread Starter
Thanks for all your advice guys. There was a leak in the fuel line which I have had addressed. As soon as that was repaired its something else. I tried to start her up one day and the clutch pedal fell quickly to the floor and wont pop back. It feels like a spring has failed or something. Does anyone have an idea what it could be this time?
post #10 of 10 (permalink) Old 01-13-2012, 03:56 AM
wbain's Avatar
Date registered: Dec 2003
Quoted: 4 Post(s)
You have air in the system or it's leaking at the slave cyl. Given the age of the car, get the slave cyl overhaul kit, a new hose, and the short hose from the reservoir to the pipe. Use a hone to clean the cyl as well. While your at it, get a replacement master cyl as well, a complete overhaul.
You then have to bleed it from below, the slave cyl. I used a power bleeder.
wbain is offline
Vibration at highway speed and a rumble! zimsc350 W203 C-Class 1 07-26-2011 07:32 PM
Strange noise while maintaining speed falling angel W123 E,CE,D,CD,TD,TE Class 5 04-28-2010 12:44 AM
Problems with speed on highway rykappes W123 E,CE,D,CD,TD,TE Class 4 12-23-2008 05:18 AM
Best highway cruising speed? rabendan W124 E,CE,D,TD Class 13 02-14-2008 02:07 AM
Why would my 420 run hotter at highway speed? guarddog W126 S,SE,SEC,SEL,SD,SDL Class 6 08-09-2007 05:29 PM
