W108 3-wire window regulator to 2-wire car - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 10-02-2011, 04:32 PM Thread Starter
Date registered: Mar 2011
Hi -- I am attempting to replace the window regulator in a '73 280SE 4.5 W108 with a regulator taken off an older parts car ('68 280S). The problem is that the '73 model car is wired for a two-wire motor and the working regulator has a 3-wire motor. I can get everything to work by connecting up/down wires as usual and the ground wire (from the motor) to the door frame, but it's tricky (it's hard to get everything connected without blowing a fuse). But once the connection is made, there's a slow "tick tock" sound from the motor even when it's not in use, as if it's continuously switching from up to down.
I've seen information here about installing a two-wire regulator/motor in a three-wire car, but not vice-versa. Does anyone have any insights on how to get the wiring to work?
Thanks
(posted to the general forum earlier - probably should have posted here instead).
ross220sb is offline
    W108 3-wire window regulator to 2-wire car ross220sb General Mercedes-Benz 0 10-02-2011 08:06 AM
    c220 wire harness 1994 injector bare wire waspkfd W202 C-Class 2 08-10-2010 02:56 PM
    Instrument Cluster Wire Issue - search a wire sheme!! jani1111 W140 S-Class 6 06-23-2010 01:16 AM
    sparkplug wire removal tool and vlv cover wire holder 560sec_vroom W126 S,SE,SEC,SEL,SD,SDL Class 3 12-17-2005 10:10 PM
    headlight bulb has ...white/ivroy wire and brownish wire vinceching W140 S-Class 1 02-11-2004 02:07 AM
