rust repair on trunk of 72 220d - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-27-2011, 09:22 PM Thread Starter
Date registered: Aug 2011
another rust repair question ...
peeling back the rubber mat in my trunk revealed this...
the metal inside the red outline is shot so I'm planning on on seam sealing ( JB weld ) 1/4 inch ( or so ) metal around this particular spot - the rest ( besides the hole in the spare tire dip ) is strong enough that I'm hoping wire wheel - naval jelly - por 15 - fiberglass resin might be enough to hold it for awhile.
I know this wont be a completely permanent solution though I'd like to at least slow down the rust and be able to use the trunk.
what I'd like to know is a few things ...
can I cover up those "circles" on the lower left and right?
after grinding and painting ( por 15 ) to the outlined area. I was thinking of using a heavy aluminum since it won't rust again - should I use steel ? any advice is appreciated
sirbenzalot is offline
post #2 of 3 (permalink) Old 09-28-2011, 04:38 AM
Date registered: Aug 2009
Quoted: 49 Post(s)
First, find the leak and fix it! It's usually the rear wind screen gasket but it could be the trunk lid gasket itself. You are wasting your time otherwise. Any little pore in the coating will allow the moisture to continue to migrate into the metal allowing the formation of yet more iron oxide.
The metal trunk floor is an integral part of the rear crash protection. An unfortunate circumstance of uni body cars is their strength is in the ENTIRE assembly and not a separate frame structure. Replace it with metal, either a trunk floor from a donor car or make a piece of flat steel to fit. I suggest welding but some people have had success with riveting AND epoxy.
Check the body struts running below the bed. They are usually okay but I have had a couple which were just undercoating covering a pile of rust.
I have never figured out the significance of the circular "lids". They seem to serve no purpose. Assembly aids? Holdovers from a previous die? Strengtheners? I dunno. I've replaced them and eliminated them with no apparent difference.
The aluminum idea will work for a short time but you'll end up rotting the remaining metal even faster.
Mike D is offline
post #3 of 3 (permalink) Old 09-28-2011, 03:29 PM Thread Starter
thanks Mike D
I agree about fixing the leaks - good advice -
the first thing I did was to replace the back window seal.
I've got to do the trunk seal as well before the rainy season.
I like the idea of welding though I have no experience (and no welder) - money is not a super big issue but I'd rather do it myself than pay someone else if possible. Don't know how difficult/dangerous welding would be since I've never done it.
the struts look ok I believe but am going to clean it off from underneath and then I'll really be able to tell.
thanks again !
    trunk corner rust repair rockcrusher R/C107 SL/SLC Class 9 08-16-2010 04:23 AM
    How NOT to repair rust JBG3 W123 E,CE,D,CD,TD,TE Class 5 07-03-2010 01:11 PM
    rust repair daryn R/C107 SL/SLC Class 3 11-07-2008 06:11 PM
    Rust Repair by MB donald1111 W210 E-Class 9 01-21-2007 01:41 AM
    Rust repair Guest Vintage Mercedes-Benz 3 04-24-2005 10:32 PM
