Vibration driving - 280 SEL 4,5 1972 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-21-2011, 01:32 PM Thread Starter
Date registered: Sep 2010
I am struggling with some random vibration on my MB. It occurs sometimes on relative flat roads with or without foot on gas pedal. Sometimes driving at about 50 mpa, it is almost nothing vibration, but another times the car vibrates a lot, feels like the car chassis jumping up and down. It sounds like a "knock sound". "The knocks" happens less rapid while slowing the speed again. When the vibration first have started, it often lasts untill the car is stopped, not turning of engine. Then i start driving forward again, the vibration is almost gone.
Any ideas? Guess if the tires was unbalanced or wheel bearing was bad, the vibration would not be random. Guess I have to check if something is loose.
280SEL4,5 is offline
post #2 of 3 (permalink) Old 09-21-2011, 01:40 PM
Date registered: Dec 2006
Check driveshaft support bushing and flex disc. These are wear items and should be replaced from time to time.
jmela is offline
post #3 of 3 (permalink) Old 09-27-2011, 08:10 AM
wbain's Avatar
Date registered: Dec 2003
Check all the mounts as well, engine and transmission, subframe mounts, rear axle mount, in the trunk under the cap. Our cars are old and rubber deteriorates.
wbain is offline
    Vibration while driving! You4eea W140 S-Class 15 12-18-2006 04:32 AM
    horrible vibration while driving mjg99 W123 E,CE,D,CD,TD,TE Class 3 08-08-2006 06:55 PM
    vibration while driving RAFA G-Class 9 06-11-2004 03:09 AM
    93 400e hum and vibration while driving c5jd W124 E,CE,D,TD Class 3 04-25-2004 06:12 PM
    Vibration while driving my 97 E320 az2md W210 E-Class 3 06-04-2003 05:07 PM
