How the heck do I remove an alternator '73 220D w115 - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 09-21-2011, 10:17 AM Thread Starter
frankflynn's Avatar
Date registered: Feb 2011
Vehicle: 1973 220D, 1988 300SEL, 1991 300TE
Quoted: 2 Post(s)
Hi All,
How the heck do I remove my alternator? Unfortunately I have the last year before you could just change the Voltage Regulator and bushes. I have to remove it and replace it.
So I have it detached easily enough. But I cannot physically remove it - the car has A/C so there is a compressor above so it won't go up, it won't fit going down.
Is there a particular way it coms out that I'm missing? I figure I could try to remove the A/C compressor or the fan and the radiator shroud - but I'd hate to do remove one and then discover it was the wrong way to go.
Thanks, Frank
frankflynn is offline
post #2 of 8 (permalink) Old 09-21-2011, 10:33 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Got a photo?
flyboyike is offline
post #3 of 8 (permalink) Old 09-22-2011, 12:27 PM Thread Starter
frankflynn's Avatar
Quoted: 2 Post(s)
I did it but still wonder if this was the best / easiest way
So I did get it done - but I wonder if this was the best easiest way to do it. And professional mechanics care to comment? First the photos:
And the other side
As you can see it's very tight - I suspect the problem is the AC compressor was an after thought and totally block what might be a very simple job.
The alternator will not come out through the bottom (at least not that I can see). I did get it out through the top by disconnecting and moving the radiator hose, the vacuum hose, removing the idler fan belt pulley and moving the fuel filter (didn't need to disconnect it - just unbolt it and move it a few inches).
Then I was able to move the alternator into the fan shroud and around to the top right hand side and then out through the space I created. Still it was very tight.
ID:	398898   Click image for larger version
ID:	398899   Click image for larger version
post #4 of 8 (permalink) Old 09-22-2011, 12:29 PM Thread Starter
frankflynn's Avatar
Quoted: 2 Post(s)
You can't even see the Alternator - it is directly under the A/C compressor. The new one is installed in these photos.
post #5 of 8 (permalink) Old 09-23-2011, 07:31 AM
flyboyike's Avatar
Quoted: 69 Post(s)
I meant a photo from the bottom, if you can manage.
post #6 of 8 (permalink) Old 09-23-2011, 04:58 PM
wbain's Avatar
Date registered: Dec 2003
You will have to remove the A/C compressor and swing it out of the way. Do not undo the A/C hoses. The solution will then be obvious.
wbain is offline
post #7 of 8 (permalink) Old 09-23-2011, 08:56 PM Thread Starter
frankflynn's Avatar
Quoted: 2 Post(s)
Now I did think of that first, there are 4 bolts that hold the A/C compressor on - two on the top side (easy to get access) and two on the bottom (seemed difficult to access). Which is why I looked for the other route.
But the other route was only easy for me because my heater control valve is leaking (see my other post) and the coolant level in the radiator was lower than the hose I had to disconnect - so I dod not have to drain anything.
So new Alternator is in, and tomorrow morning I will get new O rings, rubber washers for the heater control valve and put that back together.
It has 397K on it now - do I hear a 400 coming?
Thanks, Frank
post #8 of 8 (permalink) Old 09-26-2011, 05:07 PM
wbain's Avatar
Here are a pic or two:
ID:	400011   Click image for larger version
wbain is offline
    WTB: W115 220D. BestCarEver For Sale/Wanted/Trade/Giveaway 14 07-30-2011 07:26 PM
    W115 220D flywheel swap Petrekk Vintage Mercedes-Benz 4 04-07-2011 01:41 PM
    W115 220D asking price?? SignalRed W123 E,CE,D,CD,TD,TE Class 6 06-03-2010 03:44 AM
    WTB: W115 200D/220D pre '72 in UK coupetom81 For Sale/Wanted/Trade/Giveaway 0 03-17-2010 04:05 AM
    Question on W115 220D tointexas Vintage Mercedes-Benz 2 01-11-2006 08:20 AM
