Help - rusty 17mm bolt in subframe mounts 280 SEL 4,5 1972 - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-05-2011, 04:10 PM Thread Starter
Date registered: Sep 2010
Does someone have experience with removing them? I cant get of the biggest bolt 17mm It has become a bit rounded too. Is it better to remove the small bolts completly first, then take the biggest bolt of?
280SEL4,5 is offline
post #2 of 6 (permalink) Old 09-05-2011, 04:14 PM
Mercedes mechanic's Avatar
Date registered: Mar 2011
Vehicle: Timeship, see you yesterday, but you already knew that.
Hammer a 11/16 on it.
Top five reasons I posted in your topic:
1. You're talking about god, there has never been any god of any kind. EVER!
2. I just have a general dislike of you.
3. I am trying to tell you how to fix your Mercedes and you are not listening.
4. I'm flirting with Jody.
5. You're just to dumb to own a Mercedes, and should go buy a Honda.
Mercedes mechanic is offline
post #3 of 6 (permalink) Old 09-05-2011, 08:25 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 107 Post(s)
Soak it with penetrating oil (WD 40) overnight and see if that helps. I've used blow torches and hair driers to heat the things too.
For the broken bolt, you'll need to tap it out - basically drill a hole through the center of the bolt and screw in a reverse thread tap, which then takes out the bolt. Make sure you have spare time to do this.
Grubeguy is offline
post #4 of 6 (permalink) Old 09-06-2011, 07:24 AM
Grube's right, IF the bolt breaks, (IT did to me once) big trouble, That bolt comes with the subframe kit for a good reason, The bolt tends to rust and break-off right above the threads in the subframe. You will need a long tap drill and some precise centerpunching to drill and tap the subframe threads,
Hope that the bolt does not break.
Brian O
bostosh is offline
post #5 of 6 (permalink) Old 09-06-2011, 08:50 AM
wbain's Avatar
Date registered: Dec 2003
Quoted: 4 Post(s)
No disrespect meant, but forget WD40, it stands for Water Displacement and is great for keeping rust at bay, for shafts, engine cylinders or bearing journals.
Instead, use PBlaster, Kroil or my fave, a 50/50 mix of ATF and Acetone. Spray or use an oil can to apply the mixture to the bolt area. It will soak into the crevices and loosen the bolt. Expect this soaking and spraying to take several days or maybe a week. the ATF/Acetone is the best choice, and relatively cheap too.
wbain is offline
post #6 of 6 (permalink) Old 09-08-2011, 04:41 AM
Grubeguy's Avatar
Quoted: 107 Post(s)
Originally Posted by wbain View Post
Instead, use PBlaster, Kroil or my fave, a 50/50 mix of ATF and Acetone. the ATF/Acetone is the best choice, and relatively cheap too.
Hmmmm. I'm going to have to remember this one. Such a trick might come in handy
Grubeguy is offline
Removing rusty bolt advice. smackdog W220 S-Class 0 03-07-2011 02:17 PM
Rear subframe bushes seat rusty like the perch... Olivier A W210 E-Class 23 01-27-2010 12:00 PM
Subframe mounts? gottarollwithit W123 E,CE,D,CD,TD,TE Class 0 10-17-2008 09:13 PM
Subframe Mounts spectrumrt W126 S,SE,SEC,SEL,SD,SDL Class 4 05-31-2007 05:43 PM
subframe mounts leon W126 S,SE,SEC,SEL,SD,SDL Class 1 09-03-2002 04:12 PM
