ignition lock cylinder 1977 240 d - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-04-2011, 08:43 PM Thread Starter
Date registered: Sep 2011
okay here's my problem I am unable to turn
my ignition switch how can I remove the lock cylinder
do I have to remove the instrument panel and remove the whole lock assy in this case?
condor26 is offline
post #2 of 5 (permalink) Old 09-07-2011, 10:26 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
First, check that you're not binding with the steering column lock, it's easy to do.
Then things get a bit complicated: To remove the cylinder, you have to determine which "generation" of locking system you have. The procedure varies between them.
Hope for the steering column lock to be binding, as the job is a real PITA the first time.
Good luck,
Scott
RadioTek is offline
post #3 of 5 (permalink) Old 09-09-2011, 08:24 PM Thread Starter
Good luck,
Scott
ok thank you for your response I do have maybe three to four inches of travel in the steering wheel so does this mean that binding is not the issue?
condor26 is offline
post #4 of 5 (permalink) Old 09-09-2011, 09:14 PM
Vehicle: 1975 450SL
Quoted: 15 Post(s)
If your steering wheel immobilizer is not the problem, it sounds like a problem with the lock itself. I only Know what i had to go through when I worked on my car. They stuffed a lot of things into a small space on a 107, so things may be totally different for you.
Can you turn the key at all? Could you have a worn key that is acting like the wrong key? How long since the lock has been lubricated? What type of lubricant was used?
Do NOT use WD40 as a lubricant. It is designed to displace water, protecting metal surfaces. It leaves a film that attracts dirt. The proper lube is dry graphite.
Someone may have used WD40, and you are suffering the consequences. A guy in the 107 thread ended up having to 'flush out' his lock cylinder by spraying a goodly amount of a solvent through it. It was messy and ugly, and involved putting plastic down to catch the solvent, but he was able to get the cylinder to turn enough that he could remove it. The cylinder has to be in a specific position for removal. He then was able to get a new one through the dealership for replacement.
That's the Bad scenario. The Worst scenario involves a locksmith. That one is not only messier and uglier, but expensive.
A couple more things to try,
Scott
RadioTek is offline
post #5 of 5 (permalink) Old 09-11-2011, 11:12 AM Thread Starter
Ok so would drilling out the old lock cyl be an option if so any advice
condor26 is offline
    ignition lock cylinder lakeside W163 M-Class 25 06-13-2009 10:27 PM
    ignition lock cylinder & ignition switch lakeside W164 M-Class 2 07-23-2007 05:55 PM
    Ignition Lock Cylinder dahappybanana W124 E,CE,D,TD Class 6 04-06-2006 10:23 PM
    IGNITION CYLINDER LOCK WOES lazlo duke General Mercedes-Benz 0 11-16-2005 04:13 PM
    please help on ignition lock cylinder benz190 W201 190-Class 1 09-25-2005 05:55 PM
