Third pedal/switch in left footwell - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-03-2011, 10:54 PM Thread Starter
Date registered: Jul 2010
Vehicle: 1975 MB 450 SL
I have noticed a third switch foot pedal in the left footwell of my automatic transmission '75 450SL. It is on the far left, behind the parking brake. What is it called and what does it do? The owner's manual or Chilton's repair book have no info on it. I do not have a dead pedal in this car.
Thanks.
Shawn
Shahryar is offline
post #2 of 6 (permalink) Old 09-03-2011, 10:59 PM
Mercedes mechanic's Avatar
Date registered: Mar 2011
Vehicle: Timeship, see you yesterday, but you already knew that.
Thanks.
Shawn
Its either the foot rest or the high beam switch.
Top five reasons I posted in your topic:
1. You're talking about god, there has never been any god of any kind. EVER!
2. I just have a general dislike of you.
3. I am trying to tell you how to fix your Mercedes and you are not listening.
4. I'm flirting with Jody.
5. You're just to dumb to own a Mercedes, and should go buy a Honda.
Mercedes mechanic is offline
post #3 of 6 (permalink) Old 09-03-2011, 11:09 PM Thread Starter
I thought so too at first. It is not the high beam switch, as I tried it and no changes, and the high beam switch is on the column.
I don't think it is a foor rest, as it is way up above the level of the other pedals, right up on the back wall of the footwell. It seems to be spring loaded and the rubber covering is about 2x4 inches. I noticed it after removing the panel under the steeing column to access some relays and wiring.
Shahryar is offline
post #4 of 6 (permalink) Old 09-04-2011, 02:39 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
It might be the foot pump for the wiper fluid. It might have an electric connection too, for the wipers.
Govert70227 is offline
post #5 of 6 (permalink) Old 09-05-2011, 01:56 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 102 Post(s)
High beams are on the turn signal stalk, same as a modern car. That third thing is indeed a washer switch. It activates the wipers for a couple swipes and forces water to jet onto thewindshield. It's basically a water filled bulb that when stepped on, sprays the water. I retrofitted mine so that mashing the thing would also mash an aftermarket switch, which would turn on an electric water pump.
Grubeguy is offline
post #6 of 6 (permalink) Old 09-07-2011, 10:15 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
Switch for windshield washer pump, also turns on wipers. Take care not to stomp on it too hard, as it can be broken. Not the switch itself, but the plastic mounting/support assembly.
You also might want to slide over onto the 107 forum, it specializes in the '72-'89 SL/SLC's.
R/C107 SL/SLC Class - Benzworld.org - Mercedes-Benz Discussion Forum
Very active forum with a lot of people.
RadioTek is offline
    Switch behind the gas pedal sypherz28 W124 E,CE,D,TD Class 12 12-21-2011 06:00 PM
    what's on the left of CLS's shift pedal? vip_conan C219 CLS-Class 1 03-29-2011 12:55 PM
    Car pulls to the left a little when i press the brake pedal 50 cool 50 Vintage Mercedes-Benz 3 05-16-2010 06:40 PM
    Weird Vibration through brake pedal (Footwell Area) saxysaxo W211 E-Class 2 11-13-2007 04:13 PM
    Solution for the dead pedal carpet area (left side of brake) ushafiq W163 M-Class 6 08-28-2002 05:10 PM
